Removing cured concrete splatter.
   / Removing cured concrete splatter. #1
eCRX
Bronze Member
Ayr
2004 Massey Ferguson GC2300, 2015 Cub Cadet XT2
purchased a tractor with concrete splatter and residue all over the bucket, some parts of the sheet metal, and even a blob on the windshield.
The concrete is 1-2 years old.
Do "safe" concrete dissolvers actually work? I see a lot of mixed reviews. Or should I skip right to muriatic acid and deal with the paint as required?
20220612_213005-jpg.749940
   / Removing cured concrete splatter. #2
It will eventually wear off the FEL bucket, don't sweat it.
   / Removing cured concrete splatter. #3
Before I retired the engineering company I worked for did material testing. We cleaned the testing equipment with vinegar but you had to soak it to get results. Someone got concrete splatters on the side of one of our pickups down low. Nothing I tried would take it off so I ended up carefully scraping it off with a screw driver.
At time I would be at a contractors concrete plant and would see them spraying stuff on the concrete trucks to clean them but I don’t know what it was. Unless it’s really bugging I’d leave it alone.
   / Removing cured concrete splatter. #4
Us farmers call it the tractors work clothes.
   / Removing cured concrete splatter. #5
Even if you could get the concrete off without any damage, it will still leave a spot there. Concrete stains paint.
"Tractors work clothes", I like that one.
Wear it like a badge of honor.
Got impatient.
I ended up getting some stuff from the local concrete accessory\tools distributer called Concrete Lift off, it's a relabelled version of the stuff shown.
I put a small amount of this stuff in the corner of the bucket, it sat on the paint like water, but sizzled over the concrete. looks like it works, or maybe I'll have a gapping hole in my bucket in the morning 😋
Concrete Lift Off​
THE MOST EFFECTIVE AND SAFEST CONCRETE STRIPPER IN THE WORLD
This product is non-corrosive and non-hazardous according to OSHA and federal DOT standards. It is safe to use for concrete removal on all surfaces.
   / Removing cured concrete splatter. #7
It's probably some type of a weak acid solution.
   / Removing cured concrete splatter. #8
I like those turf tires. That's an expensive option I was lucky enough to get OEM on one of our small tractors - about the size of yours. The increase in stability using the FEL was awesome. Traction was just as good as any other tire on a light tractor except in powder snow and slick mud. For both of those we used a set of light chains.
rScotty
The tires are badly sun damage so I'm not sure if they will survive much longer.
Two years ago I barrowed the tractor and moved about a triaxle worth of dirt. No issues. I was surprised how good the traction was.
   / Removing cured concrete splatter. #10
The turfs slip enough to protect the drive train. That's an unsung advantage.
And already having the wide rims is half the cost.
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
More info coming soon! (A53421)
More info coming...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
