Removing clutch from engine shaft.
   / Removing clutch from engine shaft. #1
clytle374
Removing clutch from engine shaft.(modern BCS)
I'm swapping engines on an 852 from diesel to gas. Had a spare clutch so I didn't have to remove it for the swap, but the flange(bell housing) doesn't come off over the clutch. So the clutch has to come either way.
Does the bolt in the end of the crank shaft work as a jack bolt to remove the clutch? Or is it more complicated?
Cory
well I put some tension against the bolt and a few taps with a hammer popped it loose. I was also surprised to see Honda tapping holes with bad taps, oh well easy fix.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
