Removing blades on finish mower
   / Removing blades on finish mower #1
tld
Boston, GA
JD 2025r
Are there any tricks when it comes to removing the blades on Bush Hog finish mower?
   / Removing blades on finish mower #2
Nope, Tom, nothing unusual; just unscrew the bolt in the middle of each blade. Naturally it's easiest if you have an impact wrench.
   / Removing blades on finish mower #3
As Bird pointed out, there isn't any tricks per-se, but it is easier with an impact wrench.
At my house I have a small air compressor which is not capable of handling an air-driven impact wrench very well. So, I purchased a DeWalt Electric impact wrench, and it does the job just fine. Another reason I went that route is that I already had a portable generator such that I could take the generator and electric impact wrench out where the tractor is, if needed.
I'm sure that this is intuitively obvious, but having the tractor lift the mower off the ground via the 3-point lift is the easiest way to position the mower to accomplish blade removal task. I usually drive the tractor up on the back of my old flatbed truck (preferred) or trailer such that the mower is higher off the ground making it easier to get to the blades. (When using the flatbed truck I can get to the blades from a standing position).
Good Luck,
Kelvin
   / Removing blades on finish mower #4
Air wrench - no better solution. Perfect tool for the application.
   / Removing blades on finish mower #5
I don't have any of them fancy tools such as an impact wrench. I use a regular socket with a strongarm. A 3 foot piece of pipe on the end of that is sometimes needed to break it loose. Using the 3PH to lift the mower off the ground is OK as long as you BLOCK UP UNDER IT!!! I would never take the chance of crawling under any implement supported by the 3PH that is not blocked. A fellow I grew up with did this one day with a bush hog. His young son got up on the tractor and accidentaly hit the lift lever dropping the bush hog right on to this mans chest, killing him. Safety first please!!
   / Removing blades on finish mower #6
just make sure you don't have an odd ball and has backwards threads as to go ccw to tighten and cw to loosen..
   / Removing blades on finish mower #7
As everyone has said, an air wrench is the best way. Other tips would be to heat it red hot with a welding torch, or soak in it PB Blaster for as long as you can, or lastly even try forcing it tighter first. Sometimes this actually helps to break the bond.
Oh, and if something happens where you need to put in a new bolt, remeber they are Nyloks. Standard bolts will not do. I recommend you get them from the dealer, along with new cup washers if applicable.
And have you tried cussing at it???? /forums/images/graemlins/shocked.gif
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
148in Roll Up Garage Door (A55852)
148in Roll Up...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2013 Ford Fusion SE Hatchback (A55853)
2013 Ford Fusion...
