Removing and changing tires
   / Removing and changing tires #1
marks
San Luis Obispo, CA
JD 870
The sun is begining to takes its toll on the tires of my manlift. This lift weighs 22k, and the tires are 14 x 17.5, G range, tires and rims weigh 200#. Being that I'm in a somewhat rural area, the mobile service charge is in the $500 ball park. Granted, I haven't yet tried to break loose the lug nuts, but I assume that large cheater bar should be persuasive. Thus, jack it, block it, and use the loader for putting the tires in the truck... is there anything I'm missing?
   / Removing and changing tires #2
Spray the rim/hub with penetrating oil as soon as possible before you need to remove the tires. Many times rims won't come off a machine when the lugs are removed. If you start the soak time soon you may have a better experience later. MikeD74T
   / Removing and changing tires #3
I just replaced a set of steel wheels on my Dodge truck and had a helluva time getting the rim/hub joints to unlock. I didn't have penetrating oil, so I used ATF after heating the hub a little with a small propane torch (just enough to get the ATF to "flow"). After trying every trick in the book (and waiting half a day for the ATF to get in there) I found that more than just a puny human weight in load was required to break the grip of the rust.
In your case I would suggest cracking the lugnuts by about 1-2 turns then attaching a tow strap or chain to the side of your manlift and using the heaviest vehicle you have to put some sideways load on those wheels. In my case I was able to rock the vehicle sideways using the weight of the truck and the compliance of the springs to get it going. Since the lift probably has rigid axles, a 4wd truck in low range first gear should get it rocking... If you have a tractor to do it so much the better...
   / Removing and changing tires #4
I still have a big, 4-way lug wrench and a 3' cheater bar in the corner of my garage. I only get close to 'em if I REALLY have to...
Instead, I went to Home Deposit a few years ago and bought the biggest, electric impact drive (with black, impact sockets) that they had. And my back has been thanking me ever-since!
Once the lugs are off; the penetrating oil goes in real well around the studs and between the rim and drum. An hour or so later, with my 5lb sledge hammer and a few chunks of 2"x4" - I'm usually able to pursuade even the most stubborn wheel to come off!
Good luck.
AKfish
Elgin Pelican Street Sweeper (A51691)
Elgin Pelican...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2014 Ford Escape (A50323)
2014 Ford Escape...
