Removing a loader coupler on bx
   / Removing a loader coupler on bx #1
Tractorrr
TN
kubota bx 2370-1
Is it as simple as using wrenches to remove a coupler off a loader hose? Do you have to apply teflon on the threads before putting it back on?
   / Removing a loader coupler on bx #2
Yes and don't get any tape in the line start winding the tape on a few threads back..........
Do you wind the tape on to the right (clockwise) or left (counterclockwise)?
   / Removing a loader coupler on bx #4
No tape. Paste.
A small fragment of tape in the system can mean a huge chunk of change to remove it.
   / Removing a loader coupler on bx #5
tape or paste. needs to be for hydraulic or fuel usage. start a couple threads from the end and wind in the direction of the threads when tightening. a great tape is Mill Rose Blue Monster Blue seal tape. Around $5.00 and up.Hydraulic paste is fairly expensive.
   / Removing a loader coupler on bx #6
First of all you need to identify the type of fitting that is being used, I'm not familiar with what Kubota uses, but most newer hydraulic systems use either SAE O-ring or a O-ring face seal fittings. Neither of these require any sealant to be used on the threads because the threads are only a mechanical joint not a sealing joint, the O-ring does the sealing. Just lubricate the o-ring if its dry. If you do have a tapered pipe thread, I recommend Loctite 545 hydraulic / pneumatic sealant as it contains no fillers or particles that could contaminate system fluids, foul valves, or clog fine filters and screens and it works great. I first started using 545 when I was designing high speed punching machines that used servo valves that were very sensitive to any contamination. I've never had a leak on a joint that I use it on.:)
   / Removing a loader coupler on bx #7
Loctite 545 is the best for all your pneumatic and hydraulic needs. Learn early and be rewarded for a lifetime.
   / Removing a loader coupler on bx #8
Droptop and smokeydog win the prize for the best answers!
2020 KUBOTA RTV...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
6 STEEL KENWORTH T800 BUMPERS (A52472)
6 STEEL KENWORTH...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
