Removing a broken PTO Shaft
   / Removing a broken PTO Shaft #1
binna
Nortrac 25XT
HI Folks
Well I have a new problem my PTO shaft sheared off where entering the tractor, I have a Nortrac 25 XT, as manufactured byi Foton/Lovol TE 254 When it sheared it broke the Bearing cover which has 3 bolts, Looking the Foton Parts manual it shows parts #'s PTO Shaft FT250.41.106 and Bearing cover FT250.41.104 I hope these are the correct numbers as there seems to be others, Now the problem I removed what was left of the Bearing cover and the next ring along with 1/2 half of another ring and although the next bearing appears to be loose as does the shaft neither will pull out I though there would be a snap ring but I haven't seen one. Does anyone know how these are removed looking at some youtube video's on other tractors they seem to pull out fairly easy. I tried the PTO and it appears to be operating OK and is not making any noise as if something broken inside. I think the reason it broke I didn't have the PTO pump for my 3pt backhoe attached in the correct place and allowed stress to be excesive on the shaft. Any help w ould be appreciated, Thanks
Larry
   / Removing a broken PTO Shaft #2
Larry - Welcome to TBN. Just a safety note - modify your post and delete your phone # and email address. If you wish to receive email - ask for a PM( private message ) thru TBN.
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
Husqvarna 440 Chainsaw (A51573)
Husqvarna 440...
