Removing a BH70 from a B2601 Hydraulic Question
   / Removing a BH70 from a B2601 Hydraulic Question #1
HJPTractor
Powder Springs, Georgia
Kubota B2601
Hello all,
My first of many questions for the group. I have a BH70 on a B2601 that I want to take off. I've watched all the videos of removing other models and it seems pretty straightforward. My question has to do with the hydraulic hoses after separating from the tractor. All of the videos show simply reconnecting the male/female on the tractor and doing the same on the backhoe. Problem is I have three hydraulic hoses. Two of them are close together which I assume should be reconnected to each other to keep a closed system. What in the heck do I do with the third line?
Thanks for any advice. Relative novice when it comes to hydraulics!
   / Removing a BH70 from a B2601 Hydraulic Question #2
Third line should be return to tank which is only in use when the backhoe is on. You should just cap it off on the backhoe and there should be a cap to cover the hookup on the tractor. Same set up as my BX25 with the BH601 backhoe.
   / Removing a BH70 from a B2601 Hydraulic Question #4
Just to add to what has been said.
The BH valve has its own pressure relief valve.
When the pressure relief valve operates it needs a fluid path back to the reservoir hence the third connection.
Dave M7040
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
LOT LOCATIONS (A51222)
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A51039)
Texas Post Driver...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
