Removed a huge stump with my BX24 today.
   / Removed a huge stump with my BX24 today. #1
montelatici
Platinum Member
Croom, Maryland
Kubota B2601 and L3560 HSTC LE
I took a pic of it with my cellphone and if I can figure out how to post it I will later. I tried to remove it in the fall after I cut the tree down. The tree was only about 18 inches across but it really was wide at the ground level. I worked on it in the fall and there was absolutley no movement. Today I went out there at about 2 PM and by 4 PM I had removed it, buried it and had levelled the ground above it. **** this little tractor and backhoe/FEL is really useful.
   / Removed a huge stump with my BX24 today. #2
Congrats!! It's always fun to do useful things with your tractor. I removed a bunch of stumps last year. Have a bunch to do this year too. I just got the ripper from Bro-tek, and can't wait to see how fast it'll remove those stumps now! :)
   / Removed a huge stump with my BX24 today. #3
here's a stump I dug out last year with my BX.
   / Removed a huge stump with my BX24 today. #4
This is a safety tip for anyone pushing over trees or cutting up wind blown trees . This is one i pushed over with my excavator . nearly all tree stumps with a large amount of soil on the root ball will stand back up when the trunk is cut through . Most of the time you start your cut with the top edge of the chainsaw bar under the trunk . Cut upwards about one third of the way and then cut from the top down . As the root system acts as a counterweight it will try and stand back up and the cut your making will open up . I have used the bucket to stop this in this case , but i have seen them stand up with astonishing speed which throws the saw in the air and can easily kill . Keep this in mind if you do'nt have a machine to hold the root ball , and make sure your area of retreat is clear .
   / Removed a huge stump with my BX24 today. #5
Thats a good tip....I will be doing a few of these this spring to clear out the trail system in my back woods.
1984 AM GENERAL HMMWV HUMVEE (A52141)
1984 AM GENERAL...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
2003 Mercedes-Benz CLK-320 Convertible (A50324)
2003 Mercedes-Benz...
