Remove tires from rims with wood splitter
   / Remove tires from rims with wood splitter #1
skyhook
Veteran Member
Canada Ontario
1996 Kubota L4200 GSTC,(sold) 1994 JCB 210S 4x4x4
Has anyone ever tried or considered this?
I've heard horror stories of some people trying to remove tires off
of rims, I just purchased a set of 8/16's R1 for the front, their new and
came on a set of rims i don't need. The task at hand now is,
to remove them from the rim's, remove my old one's, and install.
I happened to look in back yard and glanced over at my 'wood splitter":confused:
Then I thought, hey, why not put the tire on top, and use the splitter to break the bead's.
put some sorta block of wood as to not damage the tire.
What do you think, has this been done before, successfully.
   / Remove tires from rims with wood splitter #2
the tires will simply roll over at the beads , there has to be a finger to get between the tire and the rim to work properly .....
go to princess auto ( or on line ) and buy the tire bead breaker ( about $60 ) or go to a tire shop...
   / Remove tires from rims with wood splitter #3
I have used my loader bucket next to the rim on my r-4's. Just be careful not to hurt the sidewall on the tires you want to keep. If you are careful and have the time , try it.
I wouldn't lay them "flat",
Stand them up.
   / Remove tires from rims with wood splitter #5
I expected you to stand them up ....
the side walls will still roll or collapse before the beads break ... and you can damage the belts in the process
go ahead if you want to , they are your tires / rims ....
   / Remove tires from rims with wood splitter #7
I've never tried a logsplitter. But I do use the tongue jack on my trailer to break beads with.
I have the trailer hooked to the truck and then set the tire under the jack and start jacking the trailer up until the bead breaks loose.
Sometimes I have to stand on the other side of the tire to keep it from coming up as well. But this method always seems to work for me.
Chad
   / Remove tires from rims with wood splitter #8
Take the valve core out-put tire flat on driveway soap on bead. Put tractor on top of one side of tire and back your truck up on the tires other side. You still will need tire irons to get it off. Go to your independent garage. Cheaper and safer.
   / Remove tires from rims with wood splitter #9
Just this week I had to break down, repair and remount one of my front tires TWICE due to some rough bush hogging.
I used the FEL to break the beads and two flat crow bars and a big flat screw driver to do the rest. There might have also been a 1/2 bottle of dish soap involved but if my girlfriend asks I'll deny knowing anything about its disappearance.
lol,,
Well, I'll be giving it a shot today or tomorrow and let you know how it went.
I have some old pieces of broken leaf springs i can use as side wedges up against the beads.
something like this shape,,,(.
I have heard of the other method's, jack's, bucket's etc, etc, just never heard of "woodsplitter".
2017 Takeuchi TL12V2 Skid Steer (A44391)
2017 Takeuchi...
(2) New/Unused Welding Helmets (A44391)
(2) New/Unused...
PALLET OF FIRST AID KITS AND HARD HATS (A45333)
PALLET OF FIRST...
AGT QK16R Mini Excavator (A44501)
AGT QK16R Mini...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2003 Ford F-450 Fuel and Lube Truck, VIN # 1FDXF46S73EC90253 (A44391)
2003 Ford F-450...
