Remove snow first or after ice hits
   / Remove snow first or after ice hits #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
The questions is, should you remove a few inches of snow from the drive before an ice storm hits or leave it as a base so you can remove the ice easier.
   / Remove snow first or after ice hits #2
Leave it til it ices.
   / Remove snow first or after ice hits #3
X2, Leave it.
   / Remove snow first or after ice hits #4
I leave the snow if there is ice coming as long as it isn't a high traffic area where it will pack down. Much easier to remove the ice if there is a layer of snow under it.
   / Remove snow first or after ice hits #6
It's unanimous...leave the snow.
   / Remove snow first or after ice hits #7
I see everyone says to leave it .
But if there's only two or three inches of snow the only thing I can say is, I've seem more times then not that it will freeze down though it and you can wind up with a very rough surface to plow. (The only time we have left snow is if we had 5 or 6" were the ice would stay on top and just freeze into a crust).
If we leave only 1 or 2" we find we get places where the snow has drifted more and in those spots you can scrap down to the base ,but where it was only a 1or 2" it froze into hard spots which made it really rough to plow. We plow around 5mils. of dirt roads on a private Island, along with cement pads . We always clean up any snow before freezing rain so to keep the surface as smooth as we can . We sand the roads after for more traction. :2cents:
   / Remove snow first or after ice hits #9
I would say good points but I also think the key is the sanding.[/QUOTE
Your right, [U sanding[/U].:thumbsup:
We have to keep the roads even.(dirt not tarred). We can't leave snow on them to freeze on and make bumps so the plow will dig in and start making the road a mess . When you work for the wealthy you have to have them the best you can get them.
I clean up the same way at my place , once I have a good base I don't keep scraping up gravel . I have a flat drive and I don't use sand , there's always some snow left on it so it's not a glare of ice, like you might be thinking.
Not for everyone but that's just the way we found to get them the best we can keep them.
   / Remove snow first or after ice hits #10
Depends on the weather. If the temps are going to drop and you just got a couple of inches of wet snow with ice on top of it you could find all of it becomes ice. Otherwise I usually wait if I can. I know some people like to have a layer of packed snow but I like to scrape it as close as I can to the dirt so if things melt I get a dirt driveway not hard packed ice that I have to sand.
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
