Remove FX32 hood
   / Remove FX32 hood #1
Peterchris
Honokaa, HI
Yanmar FX32D
I have a Yanmar FX32, and need to replace the battery. The side panels of the hood come off easily. And I see the two bolts that hold the rear of the top panel. But where the top panel is fastened near the radiator I can feel three bolts underneath the front edge. One turns, but doesn't loosen, so there seems to be a hidden nut over it. Do I have to remove the front plastic grill that hides the radiator?
Thanks,
Peter
   / Remove FX32 hood #2
Not particularly familiar with the FX32 but I don't think you should have to remove the hood to replace the battery.
   / Remove FX32 hood
The arm for the bucket is in the way. If it's difficult to remove the hood I could probably reconnect the battery, jump-start the engine, raise the bucket, and slide out the battery, but if I can get the hood off easily I'd rather do it that way.
   / Remove FX32 hood
The battery has a built-in handle, so lifting it isn't a problem. Sounds like that top panel of the hood is not designed to be removed easily.
   / Remove FX32 hood #6
Just remove the front grill, that's easy. The top of the hood has the 3 nuts welded to the bottom in the front, but I don't think you need to remove it.
The grill is the way to go..
   / Remove FX32 hood #7
My 276D has a brace between the loader arms that runs in front of the grill. Mine is rigged so that I can pull 2 pins and swing the brace forward. This allows the hood to open more. It's not ideal, but it is quick.
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
2015 Volkswagen Jetta Sedan (A50324)
2015 Volkswagen...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
