Removal of FEL from Minn Moline for restoration
   / Removal of FEL from Minn Moline for restoration #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I just bought a 1959 Minneapolis Moline 4 Star tractor that I want to restore. I want to start by removing the Moline FEL model 543. Can I just take it off and install pipe plugs where the 4 FEL hydraulic lines come out of the control box under the seat? On my Jinma, to remove the FEL the hydraulic lines to the joy stick controller must be fitted together otherwise the pump will lock up causing damage to the pump, engine, or both. It seems that the MM is designed differently as everything is internal except for the four lines going to the FEL. Just want to check before doing any damage. Thanks.
   / Removal of FEL from Minn Moline for restoration #2
If the valves are under the seat, they do not come off with the hoe, like many of our
compact tractors. That means only the work-port hoses go to the hoe itself.
There are 4 of them, and they can and should be capped with hyd caps. If you
have any doubts, the work-port hoses only go to cylinders.
This means that the IN, OUT, and Power Beyond connections to the valve are
internal to the valve or valve block. Those don't get capped.
Good luck.
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
2022 John Deere X9 1100 Combine, (A53342)
2022 John Deere X9...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
