Removal of cattails ?
   / Removal of cattails ? #1
darkday
Platinum Member
Iowa
I have a marsh that's about 2-3' deep at best and it being taken over by cattails. When it was empty we tried rototilling the whole thing but that didn't do anything. What is the best way to remove them ? I'm guessing with some sort of spray ?
Oops, I just read the sticky at the top I didn't realize this was for tractor projects only... I guess it kind of it since I tried using the tractor before ? :D
   / Removal of cattails ? #2
I hiked through a golf course this weekend and wondered the same thing. Lots of ponds, fountains, bridges. Looked like they had selectively sprayed some of the cattails, maybe 60 percent were dead and dried up. Might be a problem if any of the water runs offsite but just standing water in a marsh shouldn't be a problem. Maybe ask at the local golf course, see what they do.
   / Removal of cattails ? #3
I used to work on a golf course and the best way we came up with was to pull them out by hand. Unfortunately that is very time consuming and rather labor intensive. But it works.
   / Removal of cattails ? #4
Use what I call blue crystal, it wooks great on catails. It will also kill just about any aquaidic plant also. I think you can still get it at Tractor supply.
   / Removal of cattails ? #5
ERASER AQ is what I use to kill cattails & other non wanted growth in & around my pond.
Eraser-AQ 32 OZ. at cooperseeds.com
PRODUCT NAME: Eraser AQ.
PRODUCT DESCRIPTION: Liquid herbicide which can be sprayed along
the shoreline of ponds and lakes without risk or injury to fish
or other aquatic wildlife.
TARGET WEEDS: Anything that's there. This product will
work on any broadleaf, grassy or woody plant.
WHERE TO USE IT: Designed for use on weeds which are growing
along the shoreline of ponds or lakes. It can also be used on
plants which are growing up and out of the water. To be effective,
you'll need to have a good part of the plant above the water line
so the treatment can be absorbed by the plant and get down to it's
root system.
Marty Anderson
   / Removal of cattails ? #6
Sounds like Copper Sulfate. Unless you're carefull with your dosage you can kill just about anything growing or swimming in the water with it.
Personally, I wouldn't use herbicides in a marsh.
   / Removal of cattails ? #7
You have to be careful with it, but it doesn't harm the fish.
   / Removal of cattails ? #8
I think in my neck of the woods, coastal wetlands, they will either shoot you or take your first born for messin' with them thangs.
   / Removal of cattails ? #9
I used some stuff from the pond guy that knocked mine out and it hasn't come back.
   / Removal of cattails ? #10
If you can spray them just after you drain the pond use Roundup or if there is water in it you need to use Rodeo (think that's what it's called). Rodeo is the same as Roundup, but labeled for use on water.
Bobg
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2016 Ford F-150...
2011 IC Corporation PB105 School Bus (A42742)
2011 IC...
2019 KENWORTH T3 SERIES (A45046)
2019 KENWORTH T3...
Gas Regulator and Gas Hose (A44391)
Gas Regulator and...
WICHITA TANK 500BBL WHEELED FRAC TANK (A45046)
WICHITA TANK...
2019 FORD F650 BOX TRUCK (A43004)
2019 FORD F650 BOX...
