remote PTO speed indicator lights...
   / remote PTO speed indicator lights... #1
KrisHansen
Vermont
New Holland TC33d
You guys are going to think I am nuts, but I am in the process of hooking up remote PTO indicator lights on my 33d... I know, I shuldn't need lights to tell me I am over or under speed, but, hey, they are there, so might as well use them. The reason for this of course, is running the rear mount blower, you almost never look forward, so you never get to see the dash. I like to run my engine at the top end of the rpm band, to get the most power at the blower in heavy snow. Having the lights makes this easier.. Anyway..
What I am doing is, I soldered pitgails onto the bulb sockets on the instrument cluster, and I plan on using relays to power the 2 small lights that I will mount on the rear of the tractor somewhere (haven't decided where yet.)
hopefully, this will prove useful for someone else.. I will get some pictures as soon as I have time to actually move forward with this project...
   / remote PTO speed indicator lights... #2
If you wanted, you could use LED indicators and not need to install the relays. The LED's use very little current and last FOREVER. Probably need to add a resistor in line to cut down on the voltage, but that is a lot simpler than going the relay route.
Doug /forums/images/graemlins/cool.gif
   / remote PTO speed indicator lights... #3
</font><font color="blue" class="small">( The reason for this of course, is running the rear mount blower, you almost never look forward, so you never get to see the dash. I like to run my engine at the top end of the rpm band, to get the most power at the blower in heavy snow. Having the lights makes this easier.. Anyway..
)</font>
Kris, wouldn't you just set the throttle so you see 540 rpm on the dash and then not worry about it? Are you saying you have to actively feather the throttle to keep the engine in the 540 PTO rpm band? I guess I'm just confused as to why you wouldn't just set it once and go. /forums/images/graemlins/confused.gif
   / remote PTO speed indicator lights... #4
I guess I am kind of confused too /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif But it doesn't take much to get me confused. I would set it until you see your red light bump a bit and that is where I would leave it or a bit less. Then when you have a load on your blower you would be just right, I would't be feathering your throttle at all.
Now on my TC29D I run my MMM until I see the red light bumping on and off a bit. Then when I am mowing I am just right, however this summer my red light burned out so now I can run it full speed?? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Not really.
murph
The reason I can't set and forget is, snow tends to pile up in different depths in different places, I found that with the hydrostat, I would have to vary my ground speed a LOT to keep the engine happily revving along. I could be zooming along, then hit a big drift or something, and the engine would bog.... it's motly a convienence thing I guess... The only place I could use cruise is on the flats, of which I have precious little.
   / remote PTO speed indicator lights... #6
I was sure you had a reason. What I know about snow blowing, you could put in a thimble and still have room left. /forums/images/graemlins/blush.gif I think I understand now, but you'll have to pardon me if I don't want any first-hand experience. /forums/images/graemlins/smile.gif
   / remote PTO speed indicator lights... #7
Kris I think I would opt for the LEDs like Doug suggested. They are not likely to ever give you any problems and they are quite tolerant of the elements.
I've never felt the need myself to ever look at my dash once the RPMs are set while I'm using my blower but it sounds like a fun project just the same. Please be sure to post a few pictures once you're finished.
Maybe we could also send some snow Jim's way so he might have the pleasure of snow blowing first hand! /forums/images/graemlins/grin.gif
   / remote PTO speed indicator lights... #8
Jim, let me be the first to invite you to the Snow Blowing Academy of Central New England. Classes start in mid February. After our day long class, you'll be a snow blowin' expert. We'll call to schedule your class....we need one of those storms with a couple of feet of snow, a temperature of around -10 F, and a 35-40 MPH wind out of the North !!!! /forums/images/graemlins/grin.gif
   / remote PTO speed indicator lights... #9
He could also attend the Michigan Extension Campus - he would have to be available at a moment's notice. There he could get experience with the 30 degree, 6 inch thick, wet, heavy slush that needs to be removed before the sun starts going down and it turns into wheel-wrenching frozen channels of doom! Explore the pros and cons of PAM cooking oil spray, silicone spray, auto wax and teflon paint to prevent snow from sticking to shovels, blowers and chutes. Practice chopping through ice layer to get to the snow below. Discuss varying salt application techniques used by road crews eager to melt the snow rather than plow it. Side lectures available from arborists on pruning after ice storm damage wrecks havoc with trees.
Prerequisites:
1. Medical clearance from your doctor and a clean cardiac bill-of-health
2. Potholes 205 (learn the ability to travel ice-heaved roads)
Mike,
I already have some lights which were 'rescued' from the trash heap at work.. since the actual switching is -12v, I am not worried about excessive power draw at the cluster. I still don't know if I am going to go through with this... mainly, can't decide where to put them... anyhoo....
Yeah, Jin, till you have cut a 6 foot swath through a foot or more of snow, you haven't lived!! :)
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
Comfort Chute H Series Hoof Trimming Trailer (A50774)
Comfort Chute H...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2008 Jeep Patriot Sport SUV (A50324)
2008 Jeep Patriot...
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
