Remote oil Filter
   / Remote oil Filter #1
sos1
Bronze Member
I need to relocate the oil filter on a Briggs & Stratton Vanguard 16 horse motor.
The kids are hundred dollars or more. Has anyone ever made their own?
If so, would you please give me some help?
   / Remote oil Filter #2
Pipe fittings and nipples, put it where you want. if you can't reason it out yourself...... buy the kit.
   / Remote oil Filter #3
my guess is by the time you buy the parts fittings hoses and make a filter holder, between your time and parts the price of the kit does not look that out of reason to me,
   / Remote oil Filter #4
Maybe convert it to use a more common filter and use one of the cheaper "receivers". You still have to machine and plumb into the existing location though.
Access Denied
Wont let me link directly for some reason. Take away the () for a link to a $17 remote adapter.
(Access Denied)
Ok, google remote Oil filter and click on the summit racing result.
FWIW if you use "top shelf" fittings and hose, you will burn up a hundred dollar bill with them alone.
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
