Remote Hydraulic
   / Remote Hydraulic #1
Gera
Green River, NB
Kubota B7500
Hi;
How do I go about installing an hydraulic remote at the back of my B7500 Kubota?
   / Remote Hydraulic #2
Hi;
Does your B7500 have a FEL ?
There is probably an adapter-block available from the dealer that replaces the one that feeds a loader...if no loader is attached/plumbed for...there will just be a plate covering the access ports (power beyond from the 3PH)...attach the "adapter-block" (either way) and plumb in your new valves and quick disconnects...with either hoses or a combination of hoses and hard lines...
Good Luck...
   / Remote Hydraulic
Thanks,
I'm not sure what you mean by FEL? But I have front end loader and by looking in the book I can see what you explained about the adapter block. The dealer want over $1000.00 dollars to do the job but if possible I would like to do it myself. Anymore advise?
2018 VOLVO VNL DAY CAB (A56129)
2018 VOLVO VNL DAY...
Set of 4 12-16.5 Bobcat Wheels and Tires (A55787)
Set of 4 12-16.5...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
Heavy Duty Semi-Automatic OJ-822S Tire Changer Machine (A55788)
Heavy Duty...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
