Hooked_on_HP
Veteran Member
The brakes on my 1900 are in need of replacement. I was out of adjustment. I took it apart tonight to see what I would need. The drums were in real good shape so all I need is a set of shoes. I had priced new shoes from NH and decided against that! They are on ebay for $215. Others had mentioned buying the lining from McMaster Carr. McMaster Carr has the lining in strips the proper width(1.75") that you buy by the foot. They also have the proper rivits so I am going to reline them my self. The lining was $17 the rivits were $9. for a hundred so I will end up with under $30 in my brake job. I will let you know how I make out. Should I use any type of adheasive along with the rivits?
Bill
Bill
