Relieving Pressure in Sitting Implements
   / Relieving Pressure in Sitting Implements #1
BethesdaEC
Ellicott City, MD
JD 2520
My 2520 backhoe and loader have been sitting for the last couple of months, so yesterday when I went to remove the plow and put these implements back on I had a tough time getting the hydraulics reconnected. The implements had shifted slightly and created some pressure in the hoses that was resisting the internal shutoff value and preventing the quick connector from seating properly. I finally tapped the end with a hammer a couple of times and then they seated properly.
Is there a better way?
   / Relieving Pressure in Sitting Implements #2
I always just took a clean shop towel and put a couple of thickness over the end of the ball and hit it with a piece of wood, like a handle of a hammer, this prevents the spray from going in your face, and reduces the likelyhood of grit damaging the surface of the ball. You could probably make some kind of clamp depressor with another female fitting, but I just used the tap/towel method
James K0UA
   / Relieving Pressure in Sitting Implements #3
It can get bad enough that you have to crack open a fitting with wrenches. On my hoe it was disconnected on a cold day and reconnected on a hot one. The hammer trick didn't do it.
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2019 FORD F-250 XL SUPER DUTY SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2015 KENWORTH T680 SLEEPER TRUCK (A54313)
2015 KENWORTH T680...
