msdougherty
I purchased a Cub Cadet LTX1050 with a Kohler engine in the spring of 2014. After several weeks, I began having starter problems. It seemed to have a bad spot in the starter; sometimes firing right up, and other times you could hear the solenoid, but the starter wouldn't turn over. Finally at the end of the season last year it wouldn't ever turn over. This winter I replaced the starter and the battery, which also would not hold a charge after two years. It started like a champ after I first installed the nearly $200 starter, but now it's at it again. I can't afford these starters at this rate.
Anybody else having these problems continually? Is it a Kohler quality issue? It is a Cub Cadet reliability issue. I never expected to have these continuing problems with a Cub Cadet. Is there another greater problem that is causing these issues?
