Sprayer Regulating pressure on PTO Sprayer?
   / Regulating pressure on PTO Sprayer? #1
Champy
Indiana
John Deere 990
I was looking for a way to replace (avoid) using the 4 gal backpack sprayer for applying Roundup around my trees, and bought a used 3ph mounted 55gal tank with included hoses and roller pump at a local farm auction.
Now once I get everything repaired, hooked up and working.....how do you regulate the line pressure to the spray wand? By rpm? You don't need to?
So perhaps a more basic followup question......do I really need to regulate the pressure? I am assuming this how you adjust the volume of spray applied...but don't know for sure if this is a must-have or a want-to have. Thanks
   / Regulating pressure on PTO Sprayer? #4
A typical pto/3-point sprayer has a built in regulator to adjust system pressure that finally flows to the spray nozzles on the boom. While using the boom, normally you would turn off a hand valve that cuts flow/pressure to the wand. When using a hand held wand, simply valve off the boom, open the valve to the wand, and use the same system pressure regulator to adjust psi through the wand. Adjusting flow/volume via changing speeds of the pump would be erratic and inconsistant for the most part.
Excess pressure is vented from the regulator back into the tank. That flow is used to keep the tank agitated.
Under "normal conditions", I generally apply most spray @ 50psi.
   / Regulating pressure on PTO Sprayer? #5
With a pto roller pump, you will need to regulate the pressure or you will get to much pressure and something will blow. The pressure gauge will tell you where to set the pressure valve. You could do without the gauge and go "by gut feeling" on how much pressure you have. The gauges are not very expensive and I have seen plastic pressure valves which are fairly cheap.
Start by opening up the pressure valve all the way. Then turn the handle until the pressure increases. I tend to use 40-60 lbs of pressure. You can turn it up to 100 psi if using a hose and jet nozzle but that is pretty high.:eek: The pressure gauge will let the excess fluid bypass back into the tank.
   / Regulating pressure on PTO Sprayer? #6
You can spray quite a long distance with my hand gun at 100 psi.;) I got to playing with my new sprayer this spring and tried it with the pressure cranked up. The boom buster spray nozzles on mine for weed spraying recommend 20 to 50 psi. The hand gun works fine at that pressure. My hand gun came plumbed to be pressurized anytime the main control valve is on. My control valve has a recirculate position to mix the tank and that is the setting I use when using the hand gun.
My only complaint with my rig is that my guage goes to 300 psi. It has the fewest pressure markings from 0 to 50 psi where you need the most accuracy with the nozzles I use:( . I will probably change out my guage next year before I start spraying.
   / Regulating pressure on PTO Sprayer? #7
The only thing I would add is that the higher the pressure, the smaller the droplets and the more likely the spray is to "drift" if there is any breeze. From the replies it seems that I run mine at a slightly lower pressure than most, 40 psi.
   / Regulating pressure on PTO Sprayer? #8
I have mine calibrated at 25 psi for 12 gallons per acre and I get good coverage without chemical driping off the plants (waste). I don't have heavy (thick) brush... If I did, I would change to higher pressure (& more GPA) for better coverage. I try and spray the least amount I can but still have it work.
   / Regulating pressure on PTO Sprayer? #9
Plumb in a T with one leg to the spray attachments (bar or wand) with a gage on the attachment side, the other leg back to the tank. Add a stainless steel ball valve on the return leg. Turn ball valve to adjust bypass. More bypass = lower pressure to attachment.
2013 INTERNATIONAL DURASTAR 4300 (A45333)
2013 INTERNATIONAL...
2012 CHARLTON & HILL BATCH MIXER TRAILER (A45333)
2012 CHARLTON &...
2014 CAMBELT INTERNATIONAL CF2445 SANDBOX TRAILER (A45333)
2014 CAMBELT...
2015 FREIGHTLINER CASCADIA  CA125SLP TANDEM AXLE SLEEPER (A43003)
2015 FREIGHTLINER...
MISC PALLET OF PARTS (A45046)
MISC PALLET OF...
2007 WESTERN STAR  4900EX (A45046)
2007 WESTERN STAR...
