Regen question
   / Regen question #1
justaguyinga
Grayson
Cabela's LM55H (TYM T554 HST)
This question is on a Cabela's LM55H which, when I bought it in 2016, was equivalent to the T554hst. I was mowing yesterday and after about an hour, the engine automatically slowed from PTO RPM of 2400 down to 2000 rpm and the regen and engine lights came on.
I drove back to the barn, let the tractor run at 2000 rpms for well over 30 minutes but the lights still remain on. When I lower rpms below 2000, regen button flashes. When I increase rpms to 2000, regen button stays solid red. I can not raise rpms above 2000 even if I put the throttle lever all the way down. I tried regen process of stopping, idling, parking brake, put in neutral, press regen button for 3 seconds but nothing happens. Warning lights still on and regen button flashes. Regen light only stops flashing ad goes solid when I manually increase rpms to 2000.
Did I just not let the regen process run long enough? In total it ran for well over 30 minutes at 2000 rpm.
   / Regen question #2
My Kubota must run at 2,400 rpm initially to get the DPF hot enough to initiate regeneration. Once sufficiently hot, a separate "REGENERATING" signal appears and flashes. Once regeneration starts 2,200 rpm keeps the DPF sufficiently hot. Parked regenerations are pretty consistent around 16 minutes.
That upward oriented arrow (inside the DPF symbol) on your dash, on my Kubota indicates to increase hand throttle engine rpms to elevate DPF temperature.
Do you have an Operator's Manual?
On my Kubota this indicates the tractor is overdue for regeneration.
   / Regen question
Yes I have operator's manual. The regen process recommended is what I tried that did not work. And that particular symbol with the + sign and upward arrow is not in the manual anywhere unfortunately.
As I mentioned, I can crank the throttle as high as it can go and the engine will not go higher than 2000 rpms. I was running at 2400 when the tractor automatically took itself down to 2000 rpms.
LMC LOT NUMBER 269 (A53084)
LMC LOT NUMBER 269...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator (A51573)
2025 New/Unused...
Pallet of (5) 8 Lug Misc Wheels (A51573)
Pallet of (5) 8...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
