regarding tire air pressure
   / regarding tire air pressure #1
pcerra
Hello again
Can someone tell me the proper inflation of the tires on a T5C?
Pat
Travis thanks for the answer. I did check the sidewalls and unfortunately the writing is worn away front and back. The rear tire says something about taking the pressure over 36psi to set the bead. I did not see any working pressure listed. I set them to 30psi. Not sure if that is good or bad. I set the front to 32psi cause I think I could see 32 on the warn off writing. It could have been the year is was made, smile. Whatever shipped on a T5C from the factory is still on there. The machine is prob 20+ years old. Does that help to get a guess?
   / regarding tire air pressure #3
Let Travis have the serial number that way he can look up what year yours was built, that might give a clue...
Travis.
My machine S/N is 540723. Thanks for the help identifying what it shipped with and when it was built.
Pat
   / regarding tire air pressure #5
If it's 4wd I would drive it down a straight road and adjust the tire pressures so the 4wd does not bind. The factory pressures are a good place to start but you can find tune the pressures to eliminate driveline bind.
Tim
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2020 KUBOTA RTV...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
