Refurbishing/cleaning/painting a brush hog
   / Refurbishing/cleaning/painting a brush hog #1
james948
Shawnee OK
Kubota L5030HSTC
For a basic recap and introduction: (from previous post in attachments category)
Have been looking for a good used rotary cutter lately and finally found one that was worth my while. It is a Woods 208-2 8' pulled unit. It does need a little bit of work here and there such as the hydraulic hose stand off snapped off, but I have already welded a new on, just do not have pics of that yet. These were taken after I unloaded it and backed it into one of the bays for closer inspection.
Which showed that the gear boxes have no leaks, it is missing the rear chain guards (it has the brackets, just no chains and holder rod), and it is missing the transport lock. But all in all I just couldn't pass up a solid 8' pulled cutter for just over 2k when new ones are going for 4K+ in my area.
And also as a note of interest, the previous owner, a waste water management plant, did quite a bit of modification. They added a second wheel on each side and welded quite a bit of gusseting on any area where stress could become an issue. I'll take some close pictures with a camera instead of my phone if anyone is interested. Over all I am quite pleased.
Also on a side note, did find some seepage on two of the gearboxes after 4 hours of heavy cutting. But wow what a worker, cleared out thick grasses and brush without a hiccup.
And so now the project of cleaning it up, repairing replacing any damaged part and repainting it. I plan on either fabricating a transport lock for the cylinder or just ordering a replacement depending on what metal stock I have around. And as for one gear box that was seeping it turns out to be partly my fault. After I took the shield off to look at the gearboxes I didn't get one of the bolts that holds it on (there are only two) which also acts as one of the top bolts on the outer gearboxes. I looked at it to see why it was seeping out and realized the previous owner had stripped it and attempted to fix it by using some kind of epoxy and re-taping the hole, and now the epoxy is cracking and coming out allowing the oil to seep out when it is used. I'll have to drill out the hole and re-tap it for a larger bolt, but that means opening up the gearbox and flushing it to keep metal shavings out.
I also took the blades off and sharpened them, they had a nice rounded edge. But I noticed when I took them off that the retention bolts that hold the large pins in were not tightened all the way. I mean don't get me wrong they were tight, just not threaded in all the way, as if someone used bolts that were too long. After I had the blades off I found out why, the holes were packed with dust and plant matter. So used an ice pick and a blow wand on the compressor to clean them out and then had to re-tap the holes. And since the bolts were not threaded all the way I had to re-die them to salvage the damaged threads that were exposed and banged up.
I have started cleaning off the deck, wire brush on a cordless drill and a good old hand held wire brush as well as the air wand. And then started using a rust preventative primer. So far I am 4 cans in and looking at another 3-4 for the tongue and wheel assembly. After which it will end up matching the tractor, A gallon of Valspar tractor and equipment enamel in Kubota orange will do that. :D
Also have to get new friction discs for the slip clutch, the original ones are beyond shot, and the original owner knew it, he had the bolts on the slip clutch tightened up so it wouldn't slip :shocked: But that is an easy fix.
More to come
James
Well got a second coat of primer on over the weekend and then made it look pretty nice in my book today :)
I used a full gallon of Valspar tractor and equipment enamel. And one can of the same but in spray can form (for the little tight areas that my brushes couldn't reach). Also picked up new friction discs today at the Kubota dealership, they are also the local woods dealer which is another reason I just couldn't pass up buying this brush hog, I like having a dealer local.
Here are some pics of the past few days work, still have to repaint the drive-shaft guards and skid shoes.
James
-jayste- Thank you very much, I used it on around 15acres after I first got it (couldn't wait to try it :D ) and it is a strong cutter, but I like my equipment to last so getting it back into top condition was a priority.
James
   / Refurbishing/cleaning/painting a brush hog #5
Looks great. The next time I redo my BH I will have it Rhino Lined. That way it will last forever.
Chris
   / Refurbishing/cleaning/painting a brush hog #6
Not sure if you have a spray gun, but you can pick them up at any home improvement store and for a lot of paint, I think they are much more efficient and easier to use then spray cans or a brush. You waste less paint too... Just a thought...
-Diamondpilot- I had never thought of using Rhino Liner for the deck but if I redo any other equipment where that would be effective I will definitely be giving it serious thought.
-pilot-werx- I didn't bother with a spray gun this time since I have two or three cases of primer around. And I have a sprayer but have found that it just doesn't work as well as I would like with heavy oil based enamels that have a hardener added. Works fine for a while but then have to strip it down and clean it after a while. Of course this just may be my gun.
James
-mjncad- Thanks and always glad to share a project, I always enjoy reading up on everyone's projects I figured it was only fair for me to post mine :)
James
   / Refurbishing/cleaning/painting a brush hog #10
James what size tractor are you pulling this with?
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
90018 (A48082)
90018 (A48082)
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2001 New Holland EC215 Hydraulic Excavator (A52377)
2001 New Holland...
