Oil & Fuel Refurbish Ford 3000 GAS or Sell & Replace?
   / Refurbish Ford 3000 GAS or Sell & Replace? #1
jascott
I posted another question about replacing a Ford 3000 Gas w/ a new diesel tractor and several members thought I should just use the 3000. This is a running tractor needing some repairs and I am not sure if I should sink the time and money into this tractor.
Usage will be bush-hogging rough terrain, FEL to move small amounts of dirt and leveling/repairing roads, and perhaps running a 5' disc to clear/maintain a small food plot. Typical usage will be a few hours of use every other weekend or so.
This tractor does not have a FEL, so I would need to add this, plus a front-mounted pump and whatever controls necessary.
Current problems:
-Needs full tune-up
-Hydraulic pump leaks at engine mounting
-Clean/Repaint/Repair top half of engine, radiator, hood where battery acid was sprayed and corroded paint
-Oil Pan Gasket - leaking
-Replace exhaust from manifold down
-PTO output shaft is leaking
-New Seat
-Replace alternator, bracket, voltage regulator, battery, and battery hold-down clamps, etc.
-Brakes don't work - I have to stand on them to just slow the thing down.
-Tach doesn't work
-Throttle Position needs new friction disc.
-Power Steering Leaks
The hydraulics seem to work Ok on the rear, and it does have good power. I think this tractor has the capability of handling our tasks, but I am somewhat overwhelmed by all the work this thing needs. I know some things aren't 100% necessary, but I either want to really fix this up (short of a restoration) or replace it.
JS
2010 INTERNATIONAL DURASTAR 4300 CARGO TRUCK (A50854)
2010 INTERNATIONAL...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2020 KUBOTA RTV...
377811 (A48836)
377811 (A48836)
F550 CM Trucks 11ft Utility Bed (A49461)
F550 CM Trucks...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
