Refinishing brake dust shields
   / Refinishing brake dust shields #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Apologize if this forum is the wrong place to post this query but my GMC IS my tow vehicle. It has a set of 10 year old Kleen Wheels brake dust shields, and the flat black paint is almost flaked off the aluminum shields. Would anyone have a certain recommendation as to the best spray paint to use for refinishing them? I was wondering if the best type would be the type sold for refinishing gas BBQ grills (heat resistant). Thanks.
   / Refinishing brake dust shields #2
I would do as you said and use either a BBQ or Wood Stove paint or they also make paint specifically for painting brake parts such as calipers. You can get the first at any hardware store and the brake paint at any auto parts store.
As with anything, its all about the prep.
Chris
Chris
Thank you...I like your suggestion about the brake paint....never would have thought of that. Great idea.
   / Refinishing brake dust shields #4
I've always had good luck useing a Zinc Chromate primer on the aluminum
first so the paint has something to stick to!!:thumbsup:
THANKS for the tip !!!
Just FYI, my GMC has had the brake dust shields installed since it was new and the OEM 8-lug factory aluminum rims still look like new, despite going thru Michigan winters.. I personally think they are well worth the cost because they keep corrosive brake dust off the rims. My '04 Lesabre has the factory chrome plated Celebration Edition wheels and because the clearance to the calipers is so tight I cannot fit dust shields, the rims get so filthy I need to scrub them weekly to keep the brake dust off.
   / Refinishing brake dust shields #6
Seems most around here are going for the blakout look they never clean
the wheels!!:D
Enduro XL/C Swisher 6' Mower (A44502)
Enduro XL/C...
Pallet of Irrigation Hoses (A44502)
Pallet of...
2015 OVERLAND TANK DOT 412 ACID TRAILER (A45333)
2015 OVERLAND TANK...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A43003)
2017 PETERBILT 579...
TAKEUCHI MINI EXCAVATOR (A45046)
TAKEUCHI MINI...
2017 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A45046)
2017 GENIE GS-1930...
