Redoing ignition on Gravely walk behind
   / Redoing ignition on Gravely walk behind #1
MMist
Clatsop, OR
Mahindra 3215 hst
this is the magneto style (1970's) with the Kohler motor and electric start. Need to swap out the ignition switch and the old one is not original and a swap of wire to terminal on new switch didn't work.
Anyone know if I can go plugging into the back of the switch willy nilly without jeopardizing the magneto? or?
Regards, MMist
   / Redoing ignition on Gravely walk behind #2
Hi! The best is original or OEM part but I add a pict of Kohler wiring (Magneto electric start) engine. Good luck. Oldmech Numériser 2.jpg
Thanks for the schematic.
I picked up a Gravely ignition #018272...turns out it's a 4 position, rather than a 3 position that was in there. Plug ins 'looked' the same, however it didn't work...so I used an ohm meter to check it out and could never get a reading in the 'on' position.
Bad switch?
Regards, Scotty
   / Redoing ignition on Gravely walk behind #4
Go to gravelytractorclub.org and find the proper manual for your machine. There are many different switches that "look" the same.
I'm pretty sure there was no magneto ignition on the 1970's Kohler walk behinds. They all used battery ignition with coil/points/condensor.
The switch you probably need is the 019223.
To be sure though, get the manual from gravelytractorclub.org.
Where do I find the serial number on the gravely walk behind? Kohler Engine, electric start, alternator. Nice old machine if I can ever decode the ignition switch.
I bought a 3 position ignition switch for the Gravely...(off, on, start.)
5 plugins in back...B, G, L, M, S...the lettering system is confusing me.
I have 4 wires to plug in.
One to Coil
One to battery side of starter solenoid
One from small post in center of starter solenoid
One to (alternator?...a magnesium looking cube about 3x4x6 that is finned and sits next to the battery)
Using the multimeter on the switch it says b and s are 'START' (battery and starter?)...would that be the two leads coming off the starter solenoid?
One on side also goes to battery, smaller one in middle goes to ? (starter?)
'ON' seems to be B and L...so battery and...?
Thanks for any assistance.
We'll I went to youtube and it 'looks' as though I have a Gravely 546. Getting closer to figuring it out.
   / Redoing ignition on Gravely walk behind #7
If I'm not mistaken, the serial number on the 500 series should be on an aluminum tag riveted to the left side of the front pto casting. On the 5000 series I think they used a decal or sticker perhaps on the top of the dash just under the hood. The serial number pertains to the year of manufacture. The model number would have been in big letters on the side of the hood.
All the info you need can be obtained from gravelytractorclub.org. They have all the manuals you will ever need and they are free for the downloading.
To my knowledge, all Kohler powered walk behinds used the 019223 ignition switch.
wire from coil terminal goes to BATT. terminal on switch
wire from small solenoid post goes to START terminal on switch
wire from battery side of solenoid goes to IGN terminal on switch with an inline 15 amp fuse
wire from regulator/rectifies goes to ACC terminal on switch
2019 BOBCAT S570 (INOPERABLE) (A45046)
2019 BOBCAT S570...
2004 Nissan Armada SUV (A42744)
2004 Nissan Armada...
PALLET OF HOSES AND PUMPS (A45333)
PALLET OF HOSES...
Ariens Precision V2 Hydrostatic Lawn Mower (A44391)
Ariens Precision...
2017 FREIGHTLINER CASCADIA (A45046)
2017 FREIGHTLINER...
2003 Ford Thunderbird Coupe (A42744)
2003 Ford...
