Ballast red neck tractor weights
   / red neck tractor weights #1
homephysician
PELL CITY, ALABAMA
ym240
been searching for front end tractor weights for my ym 240. so i had a bain storm and came up with this little idea. surprisingly effective. really made my little tractor feel more stable going up hills with bushog on it. it was wheels in the air, but now it is mauverable and the steering is still very light. i call it my red
neck tractor weights:thumbsup:
   / red neck tractor weights #2
Are you gonna attach a photo?
   / red neck tractor weights #4
this worked well for me on an old Sears SS12. The rears are dual with one pair loaded and the other pair has weights. It has surprising amount of power and it flipped over on me bow over stern once so I welded a weight lifting bar to a front bracket and add weights as needed. Pretty Red Neck in my opinion
   / red neck tractor weights #5
You should Call it -Alabama Ingenuity- ;) us red necks could never come up with something like this:eek:
BTW - where did you barrow the Cinder blocks from?:D
   / red neck tractor weights #7
Cheap and cheerful. Perfect!
   / red neck tractor weights #8
I tried using cast blocks like that on my box blade for extra weight and I found that they soon cracked and fell apart. Hopefully yours will fare better.
the blocks were left over from a job. i think the weight bar is awesome on your sears tractor.:thumbsup: and i have had one block fatality but it was already cracked, but had a replacement for it. thanks for compliments. hoping it would spark an idea or two. hp.
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2012 Case 850L XLT Dozer (RIDE AND DRIVE) (A50774)
2012 Case 850L XLT...
1266 (A50490)
1266 (A50490)
2009 Lexus RX350 (A50324)
2009 Lexus RX350...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
