recovering from surgery
   / recovering from surgery #1
Dutch445
Elite Member
Upstate NY
JD X585
well, might as well post something here, won't be able to follow up every day for a while, but eventually i wil.
l
monday i underwent bilateral hip replacement. turned 50 3 weeks ago. problem has stemmed from a growth
issue while i was a young teen. at that point i had 2 surgeries, placing pins to keep the ball from moving
on the end of the femur. the only problem was there was no alignment to be done, so the joints have been
misaligned for 35 years or so, finally causing me some aches 4 years ago, into a fairly good limp and some real
bad days this past summer
i bit the bullet, and chose to have 1 day of surgery, doing both hips, with 1 recovery and 1 stay out of work
on disability. Most of my care providers ask me if i am nuts to do it this way, but many understand the theory.
my surgery went well monday, later in the day due to the complexity of it (removing pins in the process) and i
expect a couple more days here in the hospital. i have been walking since tuesday, short jaunts out of the room
with a walker, but it's all key to my rehab and getting out of here, with more therapy at home for a few more weeks,
i am able to rest comfortably, but getting up gets things riled up as expected. everybody says i am doing great,
but, i'm hard on myself thinking i should be playing hockey again this weekend (just kidding)
so anyway, i'll update every few days for now, then more as i get more time to sit with the computer on my
lap or next to me in bed.
later
   / recovering from surgery #2
Glad you're making progress, keep your head up! I wish you a speedy recovery!
   / recovering from surgery #3
Great to hear all went well. Keep us posted. I am close in age and have a steel plate in right hip, so I can see myself in your shoes - hopefully along time in the future.
thanks all
   / recovering from surgery #5
Both hips the same day? That sounds a little tougher to me than my one knee replacement. Hope the recovery continues to go well.
   / recovering from surgery #6
I had a friend who's hip joints were destroyed by chemo undergo a double replacement. I think this was after the cancer came back the second time. He went through four rounds before the lost he fight.
Had a neighbor lady go through a single at age 90. Was not long and she was out and about.
Doing the recommended therapy plus has worked for me. Get well soon.
   / recovering from surgery #7
Good luck! Sounds like it should improve your mobility once you get past the therapy and healing.
   / recovering from surgery #8
I'm very lucky to be 65 and almost no joint pain at all. Unfortunately, I inherited really bad veins in my legs and have had problems with blood clots since I was 27 years old. They first tried removing veins (stripping) and that just caused my other veins to go berserk, become inflamed, and make more clots. Because the valves have been wiped out in many of my leg veins, I get fluid pooling in my feet/ankles. This leads to stasis ulcers and lots of swelling and pain. Wearing shoes at times is unbelievably painful.
Here's the good news. If I keep my weight around 200 or less, my problems seem to go away. Actually, my heart medications seem to have improved the condition favorably to the point that I can walk, work, and do most anything within reason. Unfortunately, I also inherited a tendency to easily gain weight. This last summer I was around 260 and my legs were going to pot. I also was a mess because of low stamina and even walking around stores had to be done carefully or I'd get short of breath. I've been on a diet since August and have lost about 45 lb. Just that amount has changed my life. My legs are almost healed up and I walk around without getting winded.
There are many of us who have things we have to overcome, but it seems that often you don't have to look far to see somebody with similar or worse problems. I don't know what it would be like to have joint replacements, but I can sure identify with having to set your mind to do something and make it happen.
Dutch, good luck with your rehab. Hang in there and you'll wonder why you didn't do this sooner. I'm sure pullin' for your continued improvement.
   / recovering from surgery #10
Had a Birmingham hip resurfacing 5 years ago. Best thing to happen to me. Follow the hip precautions and don't push the recovery too fast. Joint Pain free 7 weeks after the surgery lead to a pulled hamstring muscle. I was taking the stairs two at a time again.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2009 Chevrolet Cobalt Sedan (A55758)
2009 Chevrolet...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
TANK MANIFOLD (A55745)
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
