Comparison Recondition MF vs Brand New Mahindra
   / Recondition MF vs Brand New Mahindra #1
debakas
Am based in Uganda and own 500 acres of land. this used to be a very productive farm but the civil war of 1986-2007 caused has to loose all our farm implements. I would like to acquire a tractor. Reconditioned MF vs a brand new Mahindra which would be better and why?
   / Recondition MF vs Brand New Mahindra #2
Welcome to TBN.
If the support network of available parts is about equal, then this is a fair enough comparison. You did not state whether the tractors were similar enough in size and abilities to also be a fair comparison.
"reconditioned" is a VERY nebulous term. Basically, it is simply a used tractor that has been made pretty, to varying degrees and checked out mechanically, again, to very much varying degrees. Who did the re-conditioning? Was it done professionally? Is the re-conditioner outfit reputable? How thorough was the work? What price is now put upon this used, re-conditioned tractor?
With a new Mahindra, you would better know exactly what you paying for.
   / Recondition MF vs Brand New Mahindra #3
Lots of good clarification points by BPFick. Depending on your situation, lots can be said about a good warranty. As mentioned, there are different levels of reconditioning.
   / Recondition MF vs Brand New Mahindra #4
Welcome to TBN!
Follow good advices above. Are power ranges of those tractors equal?
   / Recondition MF vs Brand New Mahindra #5
Forget about the tractors for a minute and think about what you want to do with that 500 acres. Depending on what you want to do, it is possible that you would have to go the MF route. Mahindra only goes up to an 83hp tractor, around 8,000lbs, you may need a lot bigger tractor.
Just something else to consider before you get to much time in your research. ;)
   / Recondition MF vs Brand New Mahindra #6
All Mahindra tractors have a two-year bumper-to-bumper warranty plus an additional three-year warranty on the drive train for residential usage.
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
Gleaner R50 Combine (A50514)
Gleaner R50...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 78"...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
