the old tried and true "manual labor" of picking up branches, and either a handle metal garden rake and/or a handle grass rake.
"flimsy tines" kinda acts like a grass rake.
Tractor 3 Point Hitch Pine Straw Rakes | Pine Needle Rakes
stronger beefer tines, acts more like a "metal garden rake"
Landscape Rake | Rock Rake | Root Rake | York Rake For Tractors
pull behind vacuums.
Yard Vacuum - Commercial Gas Powered - PTO Powered Leaf Vacuums - Lawn Vacuum - Lawn Sweeper
chain drag harrows, drags out clumps and breaks up clumps of dirt and smooths things out. think "chain link fence" but heavier duty and over all weight is heavier. one side has teeth, if ya flip it over it acts like a chain link fence
Tractor Chain or Drag Harrows
googleing drag harrow and came across this setup with a 3pt "forgets name" to deal with chain link fence or drag harrow
Horse Sense: Drag Field Manure With A Harrow Rake
harrow, i have one of these, its nice being able to adjust angle of the tines/teeth at different angles. and being able to add extra weight on top. (concrete blocks, logs, etc.. to get it to actually grip down further into compacted dirt and bust stuff up. and then angling the tines/teeth almost flat. so it skims the surface more and levels things out.
http://www.ranchdogu.com/DeerPage/food_plots/small_harrow_med.JPG
TNT (top and tilt) for 3 point hitch.
replacing top turn buckle of 3pt hitch with hydraulic cylinder. allows much better control of how box blades, rakes, rear blades work.
a 3pt hitch generally just raises and lowers implement. but with hyd top link cylinder, you can get better finer control of if 3pt hitch (implement) sets better on the go. to adjust front or rear of implement in how much angle it has. (encourage you to get one)
the TILT is replacing one of the lift arms (left or right) turn buckles with a hyd cylinder. allows much more finer control if left side or right side of implement lowers or raises on the go. helps with crowning rock/dirt drive ways and trails in woods and like.
again encourage you to look at bare min a TNT more so the top link of 3pt hitch and putting in a hyd cylinder in its place. allows so much more control, it is a pain in rear to constonally get on/off of tractor to adjust manually, and even then may take you a few tries to get it just right. and by the time you get what you want. the next path you might want a different setting. this is were the TNT (the top link) comes in extremely handy.
being able to adjust the top link means, tines on rakes either dig in more to the dirt, or have more of a angle to them (forward vs backward) to kinda slide across the dirt vs trying to rip down and poke down into the ground. or feathering out the dirt that is in a box blade.
operator experience can be a big thing with most implements. driving to fast, being able to adjust 3pt hitch like wanted (TNT) on the go, how wet things are / how compacted everything is.
