recommendations for pressure treated deck sealer please
   / recommendations for pressure treated deck sealer please #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Tried a search couldn't find threads in the last year.
Got a fair sized pool deck, about 40x40 that I need to reseal. Put Olympic water seal on it several (3?) years ago. Need to do it again, I've seen several new (to me) products on the market and am looking to the TBN brain trust for recent experience with the new stuff.
Behr (HD) has a solid deck sealer they claim will last 10 years and 5 gallons will cover 1,000 sq ft first coat, 2,000 sq ft 2nd.
So what are the TBN'ers using ?
Wife says I can't use a mix of diesel and used motor oil, like I did on my trailer.
   / recommendations for pressure treated deck sealer please #2
are you wanting a clear sealer? what about a solid or semi transparent stain w/more uv & weather protection? been using Olympic stains for decades, though Lowes no longer carries (here in AR)
   / recommendations for pressure treated deck sealer please #3
I tried that Behr solid deck sealer on my back covered deck, railing, and large step platforms. Anywhere it is exposed to the sun, it has peeled and disintegrated. In the shaded areas, it held up well. I definitely won't use it again!
On a new deck, we used Behr 'Fast-dry' semi transparent "oil based wood finish" last September. It has held up well for almost a year. They recommend coating every 2-3 years. With our intense sun out here, I'll probably do every 2 years.
I have found that the 'solid' stains don't hold up at all. Go with transparent or semi transparent. I do like the Behr products a lot.
We did a cedar picket fence with Thompson's water seal.....didn't hold up for even one season....real junk..
   / recommendations for pressure treated deck sealer please #4
I'm kind of a snob when it comes to paint brands, which also applies to stains and sealers. Olympic is at the bottom end of the scale. Behr used to be a really good brand, but when all the paint companies had to change how they made paint under the last administration, they haven't really figured it out yet. Sherwin Williams is easily the best of the best out there in all of their products. They also cost a bit more, but if you do this for a living, you pay for the best products to have the happiest clients. Lowes is selling Cabot again and I've had decent results with it years ago when everything was changing, but I haven't used it since then because I only trust Sherwin Williams.
   / recommendations for pressure treated deck sealer please #5
I tried Ready Seal for the first time ever this spring on a deck. Always used Flood products prior. So far, very happy with it. Goes on easy, no worries to keep a wet edge. Also oil based. Time will tell how it lasts, but so far so good.
Wood Stain & Sealer | Desk Stain & Sealer | Ready Seal
   / recommendations for pressure treated deck sealer please #6
I use Sherwin Williams exclusively for inside, outside and decks. For your deck, prep it with a stripper/rejuvenator and brightened. Prep is key for bringing back to like new. Following that, I would strongly recommend an oil based penetrating stain in semi-transparent. I do mine every three years. Nobody will guarantee anything more than a few years anyway.
Thanks for the thumb down on Behr solid.
Thanks Eddie, I'll look into SW.
   / recommendations for pressure treated deck sealer please #8
Just put a new deck up three years ago and it finally got a coat of Thompson's water seal this year. The deck is around our pool and the old deck which lasted 25 years and actually had more life but our pool had to be replaced and they didn't build the same size pool so we went bigger. Our old deck we had sealed with a semi transparent first but we went to dark and you had to hurry to get in the pool if barefoot do to the heat! We waited and hoped we could lighten it and we tried going lighter but it still retained heat. Then we moved up to paint and lighter colors which helped. The Thompson's was a bargain of price and it sealed it well so far but we are looking at giving the flat surfaces another coat this fall or in the spring. It is not to hot to walk on and the color is awesome in natural with two years of fade! It was 15.99 for a 1.2 gallon can and we put nearly five gallons on with 4" hot dog rollers for the spindles and bigger rollers for the decking. The larger areas we sprayed and rolled and in less that four hours with three working it is done and all cleaned up!
Well I went with 5 gallons of SW semitransparent oil despite some bad reviews. I think a lot of people did not prep and treated it like it wasn't oil based. Works well so far. I'l probably pick up another 15 gallons before the 35% sale goes ends August 12th.
Not that SW has a 15% military/former military discount.
To qualify for the 15% off Military Discount, you must:
Be currently serving, be a reservist or have served in the military, including the US Army, US Navy, US Air Force, US Marine Corps, US Coast Guard, the National Guard, ROTC, Royal Canadian Navy, Canadian Army or Royal Canadian Air Force.
Be able to provide an ID at the time of purchase validating military service.
   / recommendations for pressure treated deck sealer please #10
I didn't read the reviews, but have heard clients complain about staining a new deck and how it didn't last, or it was really blotchy. When I asked how long they waited before staining, every single one of them said that they didn't wait, or they stained the following week. Modern day treated wood needs at least four months to dry out before staining or painting. Six months if it's going to be over winter. And that's here in Texas. I might wait a full year if I lived up North!!!
NEW SIMPSON 3400 PSI PRESSURE WASHER HONDA ENGINE NEW SUPPORT EQUIPMENT (A40018)
NEW SIMPSON 3400...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
Daewoo G15S Forklift (A44500)
Daewoo G15S...
2016 Freightliner Classic XL BOX TRUCK (A37762)
2016 Freightliner...
2021 John Deere 5055E Tractor (A44391)
2021 John Deere...
2015 John Deere 6115M, 115HP, 3 Sets Rear Remotes, Air Ride Seat, Powerquad 16/16 Transmission (A44787)
2015 John Deere...
