Recommendation Please
   / Recommendation Please #1
keegs
Veteran Member
The County, ME
Kubota M5640SUD
Hey guys,
I have about 5 acres I keep cut at our second home. I'm there at least once a month during summer (usually more often than that) and for years have been using a 22" self propelled lawn mower and a walk behind string trimmer to keep things in trim. The string trimmer bales me out when I let the grass grow too high but that added step obviously increases the time it takes me to mow.
The landscape is mostly flat but there's a slope in one area down to a small pond. The smaller, lightweight, self propelled mower works well with the slope but the narrow cut makes it slow going. It can take 2 days to cut the lawn. There are some dents and mounds on the landscape and the occasional rock thrown out from the driveway by the snow blower to look out for.
I don't mind a walk behind and think of it as exercise. Something with a wider cut is going to be much heavier so I'm looking for something that's somewhat on the lighter side of big mowers, maneuverable and propels itself. I'm not made of money so my instinct is to look around from something used. I have a garage for storage.
Your thoughts?
   / Recommendation Please #2
Are u considering a 42" rider.?? Lots of them cheap in your local Craigs List..
I'm partial to TroyBilt.. LOTS & LOTS of years outta them.. w/ minimal repairs.. just belts & blades * change the oil 1x a year.
SAME w/ a self prop. walk behind..{100.-150.00used}
I've got two TB's. The oldest needs a new deck (it was left unused outside for a few years but it was free :) ). A motor mounting flange on the other mower cracked but I was able to repair it. Not sure how long the repair will last though, hence my search. My preference is something that's self propelled with a wide cut 48" or more. I'll poke around FB and CR for Troy Built. I've had good service from these two. Thanks!
   / Recommendation Please #4
48" of thick, deep grass will require 20+ horsepower. Especially if you have to go uphill figure 25hp
   / Recommendation Please #5
I agree, very economical.
I have a 2011 Ariens $900 HD special, gear drive. Sold under many names. It has survived my teenage son, Florida sand on an acre. The deck is easy to maintain and cheap (I've rebuilt it twice). The gear drive is bullet proof. It's not pretty to look at, but gets the job done, and there are lots of them for cheap. It also does a good job pulling a small yard cart, max weight 750lbs (flat ground). range seems to be $250 to $450 consistently. A minimal investment.
   / Recommendation Please #6
I WAS bragging about my T. Bilt & yesterday I was cutting grass after about 2 weeks worth of rain had past..
The deck started getting a little wobbley & started shaking a little.. I just thought it was from the tall grass & maybe a little wet.??
All of a sudden all h*ll broke loose.. Come to find out the spindle bearings seized & smashed the spindle housing sending parts scattering.. LOL..
Its nothing that cant be fixed.. but I thought it was funny after I was bragging on it..
After researching the part, I noticed the aftermarkets come w/ a zerk grease fitting, where the oem doesn't..??
   / Recommendation Please #7
Just get double sealed bearings
   / Recommendation Please #8
Kyle.. THATS what I did to the "other side" when it seized, just about this time last year.lol.
I noticed they used sealed on 1 end & open ball brgs on the other..{stupid}
I replaced those w/ sealed & never gave this "new side" a thought..{stupid}..
BUT, when this side seized, it broke the housing.. beyond re*use..
After researching it, I have to buy an assembly w/ a pulley attached.. I WAS gonna just buy a hsg. & brgs. No Go.
"THEY" wanted 81.00 for the assembly.. & 16.37 EACH for the brgs IF I could find a hsg..
I found the WHOLE ASSY for 33.00 w/ f. shipping on another site..
   / Recommendation Please #9
Do you really mow 5 acres? With a 22" push mower it seems that would take over 10 hours. Even with a small riding mower it would be a lot of time. Short term, I would find the largest riding or zero turn I could afford. Long term, I would try to convert the lawn to maintenance free landscaping.
   / Recommendation Please #10
Do you really mow 5 acres? With a 22" push mower [..]
This was my first thought. Anybody that mows 5 acres with a push mower is a stud. Respect.
Komatsu Midi Excavator (A51691)
Komatsu Midi...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
1262 (A50490)
1262 (A50490)
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
