recommend a good thickness of stick please
   / recommend a good thickness of stick please #1
andrewj
Platinum Member
South Carolina
JD 5105
I believe this is my maiden voyage into the welding subforum, so please excuse my ignorant question, just here to learn.
I used a quarter inch 6014 rod arc welding some soft steel and had a hard time getting a good bead, someone suggested a slimmer rod. What do you guys think?
Took a welding class in high school. then I lived decades of life and forgot that stuff, haha. Now I am doign a little project welding and messing stuff up.
I have a arc welder - the adjustment is a little hard to manage as it is old and tends to move around. Once ai get it set it seems to do OK.
   / recommend a good thickness of stick please #2
I've burned a few rods in my time, but honestly can't say I've used any 1/4 inch rod. Generally if I have to use anything bigger than 5/32 inch rod I switch to wire feed.
In my opinion, average guy can get by just fine with 3/32, and 1/8 inch rod.
   / recommend a good thickness of stick please #3
1/4" rod??......are you measuring the flux on the outside too.?...if not that's a big rod
agreed with Shieldarc, 3/32 and 1/8" is fine for most jobs
   / recommend a good thickness of stick please #4
I generally use either 3/32 or 1/8, mostly 7014 or 6011. I use 3/32 on material under 1/8"-3/16" thick and the 1/8 on heavier stuff.
1/4" rod is pretty serious stuff, I've never even seen one that heavy. Like wdchyd said, the rod is measured on the actual metal diameter, not the flux.
You probably have the Century style welder, with the sliding current selector. I have the same type, makes me wish it was a Lincoln with the dial selector, since mine occasionally moves too.
Sean
   / recommend a good thickness of stick please #5
1/8" 6013 (low pentration) lesser chance of burn through
1/8" 6011 (deep penetration) good for minimal material preperation
3/32" 6013 for thin material
Print this links info, a good reference when in question.
Rod Selector for Stick Welding
   / recommend a good thickness of stick please #6
Might depend on the welder output.:D
   / recommend a good thickness of stick please #7
Give us some more details, Andrew. What thickness of metal are you welding? What kind of problems are you seeing with the bead? What kind of rod are you using?
For my own amateur welding I usually only use 7014 or 6013. Any other kind of rod gives me results I'm not happy with. I use a rod selection table like rhett linked to to choose the rod size.
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
