recall and hydraulic oil
   / recall and hydraulic oil #1
Anonymous Poster
Epic Contributor
What is this recall and oil switch I am hearing about? Do it effect my TC25D I just bought?
If the recall affects your tractor which I assume is a TC model, New Holland will send you a letter stating so. If you have not recieved one yet, it probably does not, but I would check with your dealer to be sure. As far as the oil change, New Holland has a lighter, thinner weight hydraulic oil called F200. Mainly it is designed for tractors run in colder climates (New York) to help speed up the hydraulics and reduce the whine in hydrostatic tractors during cold weather operation. Check other postings for more info and to hear what others opinions are of the F200 versus the 134!
Exmark Zeroturn (RUNS) (A50774)
Exmark Zeroturn...
2016 John Deere 5100M (A50120)
2016 John Deere...
2004 John Deere 6215 (A50120)
2004 John Deere...
2016 Genie S-45 4x4 45FT Telescopic Boom Lift (A50322)
2016 Genie S-45...
Skid Mounted Controls (A50121)
Skid Mounted...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
