Iplayfarmer
Super Member
I've decided that it may be easier to consolidate my progress and questions by making one thread about rebuilding the hydraulic system on my TerraTrac GT30 crawler. Thank you to all for your input on my other two threads here in the Hydraulics forum. In keeping with the status quo on TractorByNet you've helped me to spend more money than I had originally planned. I ordered two double acting 34" stroke cylinders that should arrive sometime next week.
The attached picture is of the culmination of an entire days work. I took yesterday to measure, mark, and calculate what the bracket would need to look like in order to mount the new hydraulic pump so that it AND the alternator can both be driven off the fan belt. It doesn't look like much, but I consider it a masterpiece. I'm sure I'll have to modify something on it by the time this project is over, but for now it's great.
I had some questions about the size of my valve, but I think I've resolved them. The pump I bought says that it's rated for up to 10 GPM, and the hose size guide says that I need larger hoses for that kind of flow. But, the pump's suction and pressure openings are the same size as the fittings on the valve I have to use, so I'm going to go with it.
What has filled my idle thoughts today has been where and how to mount a filter. I'm sure I want it after the tank before the pump suction port. The most likely place is out on the front of the crawler. Is that a bad idea? Do these filter have to be mounted right side up, or can I mount it sideways?
The other challenge I'm going to face is routing hoses for the lift arm cylinders. The older cylinders were single acting, and the new cylinders are double acting. I'm going to need a place for another two hoses. The current configuration includes a hard line plumbed across the front of the operator station. I may try to add a second hard line since I think that would look the best. Can good old galvanized pipe be used on a hydraulic system?
