Rebuilding one of two loader cylinders.
   / Rebuilding one of two loader cylinders. #1
Alan7s
Sharon, CT
Terramite T5C
I noticed some minor leaking on one cylinder of my Terramite loader so I replaced the seals. The other side seems OK (no visible leaks), but I wondered if the piston seals which I can't see could be worn and therefore the refurbished side would be doing more of the lifting and causing some sort of strain, or is this something not to worry about? Thanks
   / Rebuilding one of two loader cylinders. #2
I noticed some minor leaking on one cylinder of my Terramite loader so I replaced the seals. The other side seems OK (no visible leaks), but I wondered if the piston seals which I can't see could be worn and therefore the refurbished side would be doing more of the lifting an onesd causing some sort of strain, or is this something not to worry about? Thanks
The cyls are teed together if either piston seal leaks it will drift down. No drift means they are both holding. The bad thing is usually the piston seals are not far behind the rod seals for failing unless the rods Are damaged. CJ
OK that answers that; there is no drift down so they are both holding. Many thanks.
2006 Kobelco SK210LC Hydraulic Excavator (A49461)
2006 Kobelco...
3in Poly Pipe (A49461)
2017-2023 Chevrolet Silverado Pickup Truck Bed (A49461)
2017-2023...
2020 KUBOTA RTV...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
