Rebuilding hydraulic pump 1952 8N
   / Rebuilding hydraulic pump 1952 8N #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
How involved is this? The hydraulics are getting real weak, struggles to lift my 4ft bushhog. I have good basic mechanical skills and basic hand tools, some air tools.
   / Rebuilding hydraulic pump 1952 8N #2
about 4 hrs to drop the pump R&R and put it back in.
I'd spend another 4 hrs and go thru the hyd cover as well.
many times a weak lift is a combo problem. worn pump, weak relief,a dn a very leaky piston cycl.
a leaky piston can cause a weak lift even if the pump is good as it maxes out at 1700 psi and 2.85 gpm with the engine screaming. if the leak is huge fromt he a bad hydro piston.. you won't get much lift.
you may or may not need a cyl.. I'd plan on a new piston, oring and backup washer.. top cover gasket.. 3 gaskets under the cyl.. pto flange gasket.. inspection cover gasket.. hyd pump lower gasket.. new relief valves.
if the pump chambers need repalcing you will need gaskets and parts for them.
have an fo-4 I&T manual on hand. you can fo this via cook book.
trhis is a good time to clean the rear sump singe the pto shaft comes out.
check it's seal as well.
   / Rebuilding hydraulic pump 1952 8N #3
Do you have water in your your oil?
Thanks Soundguy. No, no water in the oil. I will start on this soon and post back results.
   / Rebuilding hydraulic pump 1952 8N #5
post if you hit a snag.
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
UNUSED CFG QH12R EXCAVATOR (A51247)
UNUSED CFG QH12R...
Informational Lot - Financing (A53473)
Informational Lot...
