Yes, grease is necessary.....
Just use caution, don't scratch seal surfaces with sharp oring picks (including inside gland/piston grooves where seals are installed)....
Polish everything a seals touches (including inside gland/piston grooves where seals are installed)...watch your leading edges where seals have to pass by (they should be dull/rounded)
Buy premium seals when avail.....(those orings/backups on piston head and inside glands can be updated to much better seals).....sometimes OEM seals are not the best.....
Clean, Clean, Clean.....then wash hands/tools ...lube and reassemble......pay attention to "Fit & Finish" and you'll do fine.....
