Rebuild a generator?
   / Rebuild a generator? #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
Just wondering out loud. A relative recently bought a used generator, for cheap, and after a bit got it running. It ran and worked for a few days then quit generating. My BIL checked the windings and they are open. I wish I could tell you the brand but do not know it. It does have a 7.5hp Tecumpseh engine that runs good, they say. Of course there is always something you can use the engine for but they were wondering if it's worth it to rebuild the generator?
Or pick up a new generating unit and connect it to the motor?
   / Rebuild a generator? #2
I think if he windings are open circuit, then part of the coil is likely burned out. I don't think you could do a rewind yourself, maybe there is a shop that could do it but likely it would cost as much as a new generator head. It might be cheaper to just buy a new (or used)generator and keep the motor for a spare.
   / Rebuild a generator? #3
You can buy generator heads from places like Norther Tool, but it might take a bit of searching to find one that fits. An electric motor shop should be able to rewind it.
   / Rebuild a generator? #4
Not a generator, but interesting pricing. We have a bunch of 19' electric scissor lifts at work. The hydraulics are powered from a DC motor. The lifts range from 3 to 6 years in age and repairs are increasing as they age. An equipment company replaced one of these motors and charged us around $1,100 for the motor. I almost vapor locked and searched for a replacement. I managed to get an OEM motor for $600. One of our guys said he had motors rewound at a place in town when he worked for another contractor. We took a motor to that shop and the bill was $200.
   / Rebuild a generator? #5
Where did he meter the windings ?? Before the brushes or after,, If it's a brush type ?
   / Rebuild a generator? #6
One thing to consider when making your decision. Most generator/engine units bought as a single unit have the engine crankshaft supporting one end of the generator armature. To do this the engines have a tapered shaft which makes them almost useless for other applications.
There are a limited number of taper crankshaft adapters on ebay but find one which will fit is hard. The adapters convert the tapered crankshaft from a pater to a straigt shaft with a sleeve which sildes over the taper.
Crank Shaft Adapter Taper to 1" inch Generator Pressure Washer Engine Bushing | eBay
Buying a new generator head designed to work with the tapered engine shaft you had is also very hard.
I approached a rural motor winding place with the stator of my honda EM3500 and they would not do it. They said the ones they had done were not reliable.
Unless you are a machinist or know one it is often best to retire the unit.
Dave M7040
   / Rebuild a generator? #7
I had a 5kw Sears generator, (made by Onan) it quit making power. I ended up having to take it to an Onan repair place as Sears wouldn't touch it, and they said there was a $60.00 charge to check it out, so I left it there.
After a time, they called me and told me it had a bad armature and as Sears didn't order ANY spare parts, there were NONE! They contacted the factory and was told that all they had was the blue prints, if I wanted an armature, they would have to make one up! The cost ?, $600.00 plus!!
I had to pay $60.00 to find that out!
SR
   / Rebuild a generator? #8
Prior to Y2K small generators cost approx $1000 per KW so they were repaired . Now generators cost $100 per KW . If anything serious or $$$ goes wrong. Sell the clunker in the classified ads to some cheapskate looking for a fix it bargain and purchase a new generator .
Thanks for the replies. After reading this and other info, he bought a new one.
   / Rebuild a generator? #10
With today's labor rates more and more products are 'throw away' with electronics being the best example.
I have seen so many electrical items tossed that only needed a new plug that I wonder.
I have a pal that gets all he wants from the local recycle and I am amazed, no dumbfounded.
He and I in about 2 hours returned all sorts of tools back to life (at 0.00 $) and just last week end he ran a garage sale and made $750. selling other folks discards.
Nail guns that simply needed a new trigger (sold for $100)
Table saw that had frozen(rusted) screw adjuster,
Chop saws with broken line cords.
At least 6 corded drills, (guess most wand battery drills now)
Canoes, peddle boats etc etc (fiberglass is super easy to use for a repair), he gets easy $200 as long as no leaks but he does guarantee.
Folks simply do not know how to fix or repair any more, or simply don't care.
Just today I helped him with a Bostitch 3 1/4" coil framing nail gun. A simple trigger and 10 mins had that nail gun running like new.
Repair: $27.00 for parts , cup of coffee for me, and he'll sell for about $200.
We do this as a hobby, (he for $$ to supplement his pension) me to keep active.
We are in a disposable society! face it.
WICHITA TANK 500BBL WHEELED FRAC TANK (A45046)
WICHITA TANK...
2023 EAM Ramp Star 15,000 Gallon Ramarco Tank Jet Refueler Truck (Ramp Master) (A42742)
2023 EAM Ramp Star...
Chery 7' 10 Drawer Workbench (Blue) (A44502)
Chery 7' 10 Drawer...
2018 Kubota SVL75-2 75HP Track Loader (A44789)
2018 Kubota...
2006 Ford F-350 4x4 Pickup Truck (A42744)
2006 Ford F-350...
2006 IC PB30500 School Bus (A42742)
2006 IC PB30500...
