markrahn
Bronze Member
For all you guys who have experience with things of concrete. Specifically monolithic concrete slabs. I am building a 40 x 60 with a brick ledge all the way around. So the forms are building out to 40' 11" x 60' 11". The footings are dug so from the bottom of the footing to the top of the slab is 32 ".
I am doing my own steel work, so I want to know what size stirrups I need and how far apart to space them.
How far off the bottom of the footing does the bottom runs of rebar need to be?
How close to the top of the slab does the top runs of rebar need to be?
How many runs of rebar do I put in the footings?
Should I "tie" the corners with diagonal runs of rebar?
Can You tell I am a rookie?
By the way. Man has the cost of rebar gone up or what:confused2:
