Cliff_Johns
Elite Member
I've seen a lot of comments about rebadging tractors between brand names. Usually it's derisive, but I'd like to point out that rebadging isn't always the right term and having another company built part or all of your tractor isn't always a bad thing.
Just because a particular factory in China makes a Table Saw for Hong, Grizzly, DeWalt and Delta, does not mean that the Delta is a rebadged Hong. It often means that the same factory makes them -- that's all. Sometimes it means that the same assembly line makes them, but for key components, they pull parts from one box for Grizzly and another for Delta. Sometimes, machining stops at one stage for one brand and a different stage for another brand producing a smoother or flatter table top. Sometimes the brand name is attached, after the final quality control points.
My point is, that a factory is often building machines to the spec of the badge, not building a bunch of machines then putting the badge on them. And just because you look at the two and they look the same does not mean they are.
Of course, sometimes rebadging really is rebadging, but you can't know that without actually going to the factory and watching every step of the process.
Please believe I'm not defending/attacking or complaining. Just observing that our use of the term "rebadged" may be misleading or wrong in many cases.
In the current TBN climate, I admit I'm a little hesitant to post this, but I think it's an important distinction to make. I hope I haven't offended anyone.
Cliff
Cliff
