Rears Flail Mower Experiences?
   / Rears Flail Mower Experiences? #1
biodegraded
Lane County Oregon
MF 1754
I am seeking input from people who have experience with Rears flail mowers. Search brought up posts mostly from 2008 or earlier. The epic "Let's Talk Flail Mowers" thread might as well be called the Caroni thread. :laughing:
I am interested in a sturdy, honest medium duty unit with great longevity with proper maintenance. Tractor has 45 PTO - am thinking ~84" cut. It would be used for 10 acres of brush, pasture, fence lines, drive path / road edge tasks. No lawn duty will be involved. I'm looking especially at Rears because I live near them - my day job is in Eugene. I'll of course call them for suggested models, but they're selling something, and independent experiences can be invaluable during the research phase. Input welcome.
   / Rears Flail Mower Experiences? #2
I have a bit of experience. :D
   / Rears Flail Mower Experiences? #3
Ford/NH 917. Can't say much more that nasn't been said.
   / Rears Flail Mower Experiences? #4
I guess that was mean.
I have the SPF model, 72 inches. I use it behind a 50 hp pto tractor. There are NO FLIES on this mower but if I were to do it again, I would get the FL940 knives. I ordered mine with the 960s and while they do a great job, I occasionally think I may be beating on the machine a bit.
I do love the fact however that I can change blades without tools and I switch back and forth between the grass blades and the side slicers, with the grass blades it will honestly make as pretty a cut on a lawn as a reel mower, at least in my opinion.
I also wish I had the low profile unit and a bit wider cut. 84" would be great.
As far as maintenance, I have replace one roter bearing and both rear roller bar bearings but otherwise, the thing has been bullet proof.
I looked at a LOT of flails before I decided on the rears and I will buy another if the occasion ever arises. It wasn't cheap but after a couple of uses, I never looked back.
It's rather heavy, especially after you get a bit of gunk caked up underneath and on my L3240 without the loader, i had to use the turning brakes. My L5740 does not have that problem.
My brother in law just bought a Land pride flail and while it is a nice machine, it doesn't seem to be as robust as the Rears and it cost more.
Anything else you need to know, I be happy answer if I can.
   / Rears Flail Mower Experiences? #5
98% of your decision is going to involve your wallet, 1% is what your cut is going to look like and the last 1% is
whether you want a 7 or 8 foot flail behind your mule.
You have plenty of power for an 8 foot finish flail mower, my father used his Ford Jubilee and a 7 foot JD25A finish flail to
reclaim pasture with 12-15 foot golden rod and underbrush to the point where he mowed 4 acre sections every other
week so power and mower size are not an issue YOUR TIME IS.
The lower the cutting height the better PERIOD. this makes the next weeks or biweekly mowing that much easier.
Do not forget at one mile per hour you are traveling at 88 feet per minute, at 2 miles per hour 176 feet per minute.
With a seven foot flail mower you are mowing almost 37,000 square feet per hour at one mile per hour and at
two miles per hour you are mowing 'almost 74,000 square feet per hour you have to think of it in those terms only
as your seat time is going to determine the solution to your algebra problem NOT whether your implement builder is near you.
Do not assume that you can operate a flail mower at less than the 540 RPM engine speed as the cut will be very poor as
the flail mower rotor will not be rotating fast enough to cut efficiently by creating the necessary pressure gradient to
create the lift need to slice and lift the clippings at the same time.
SO mush of this is going to be dependent on the ground conditions and the brush height as the mower must be on the ground to create the pressure gradient to work effectively as the side slicer knives become airfoils to to the work of slicing and creating the lift needed to carry the clippings up and over the flail mower rotor.
If you mow at a 2 inch height you will have many fewer problems and the clippings will rot much faster and decompose back into the soil.
The lower you mow the better as the brush will not get ahead of you ever!
you will also be able to mow in reverse backing over brush clumps and then driving forward to shred them even more.
You will have to shop if you are intent on buying new, SAYING THAT I would rather see you purchase a used or 7 or 8 foot JD25A
for your first season and then decide if you want new as a used flail mower will operate exactly like a new one with proper maintenance.
You should look at the auction time web site as well as tractor house as they have many used and new flail mowers for sale that may be excess inventory or from one owner estates and farms have very low hours on them.
You do not really need a heavy flail mower for what you are describing just adequate maintenance and spare knives for a 4 row finish flail mower that will give you years of service.
You have to decide if you want a true "flail shredder" with a rougher cut or a flail mower with a high number of knives per row, I think you will be very satisfied with a finish flail mower for your use- the high departments use the finish flails for road verges and ditch mowing as they are much safer to use while mowing along roadways.
   / Rears Flail Mower Experiences? #6
A few years ago I had some extensive experience mowing with Alamo mowers on a 6610 Ford mowing antenna fields (500 acres) at a military radio transmitting station station in Louisiana. We also had some batwing style bushogs for the same work. The flailmower did a superior job. We even started using it for the grounds around the buildings and used lawnmowers only for the really close spaces. 15 years later I own my own mowing business and got my first flail mower this year. I'm using an "extinct" Vemco 72' mower because that's all I could find and afford in NM. Not a place where Flail mowers are well known. Where I currently mow the flail mower has changed what comes back after mowing. Fewer weeds, and more grass are now in the spots I mow. The previous guy used a bushog type mower and thats what I used my first year. Now I use only the flail. Yes its more maintenance, but the result is worth it. All I have to do is show a potential customer what It looks like after a couple weeks and they're usually sold.
   / Rears Flail Mower Experiences? #7
That antenna field story utterly facinates me. I am a Radio (Ham) guy and have had a thing for cutting grass all my life it seems. We had many Alamo flail mowers go dirt cheap up here at municipal auctions.
I bought a fourten foot Alamo Finishing mower at one of these Auctions. Up here I found the parts prices crazy! A half inch (reverse thread) blade bolt could cost you twenty bucks! And you could go through three in twenty minutes bottoming out on ground hog mounds or ant hills.
The FORD Flails always had such reasonable parts prices I thought. Once I even thought I had died and gone to heaven when I found a good amount of unused 917 flail knives at the dump!
Thanks to all who replied, especially sassy allen in texas. The thoughts are much appreciated.
Edit note: leonz, I don't know what goldenrod is, but I was encouraged when you reported your father's reclamation using a finish mower. I have a few acres of 12-15' blackberry patchs, 8' reed canary grass, which is dense stuff indeed, 2" stem thistles, bamboo and other invasives to demolish. Even the places where there's pasture grass, it's nearly 6' high. One thing out here, though, is after about this time of year, most stuff stops growing. When it's cut, it stays cut till next growing season.
Stihl KM 130R String Trimmer and Edger (A49461)
Stihl KM 130R...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
