rearend lubricants for 1968 ford 4000
   / rearend lubricants for 1968 ford 4000 #2
Re: Hydraulic Fluid
Here is the partial info from Citgo.com Mystic
M Y S T I K ® J T - 5 ® U N I V E R S A L
T R A N S - H Y D R A U L I C F L U I D
M 2 0 0 1 4
Exceeds the Requirements of John Deere J20C
Mystik JT-5 Universal Trans-Hydraulic Fluid provides excellent performance in modern agricultural
equipment. It offers outstanding gear wear protection, brake chatter control and oxidation resistance.
Particularly well suited for hard working applications where an added level of protection is desired.
Excellent filterability characteristics along with rust and corrosion inhibitors, water tolerance, and
wide temperature range performance.
• Exceeds the requirements of John Deere Specification J20C
• Meets the performance requirements for Sundstrand Hydrostatic Transmission Fluid (HTF)
• Meets the pump performance requirements of Denison HF-O, HF-1, and HF-2
• Contains special “friction modifiers” for superior brake chatter control
• Formulated to resist leakage
• Formulated with advanced detergent/dispersant, antiwear, antioxidant, antirust, and
antifoam additives
• Has proven field performance
• Offers performance in industrial and construction equipment calling for Allison C-3, or
Caterpillar TO-2
MYSTIK® JT-5® UNIVERSAL TRANS-HYDRAULIC FLUID
Material Code 663509002
API Gravity, ASTM D 4052, °API 30.2
Density, lb/gal 7.3
Specific Gravity 0.88
P R O D U C T I N F O R M A T I O N
M 2 0 0 1 4
RECOMMENDED BY CITGO TO REPLACE
ALLIS-CHALMERS CORP. DEUTZ-ALLIS MASSEY-FERGUSON
Power Fluid 821 AC Power Fluid 821XL Permatran® - III Fluid
M-1135
J.I. CASE FIAT-HESSTON M-1141
TFD Fluid No. 143 M-1110
TFD Fluid No. 183 FORD NEW HOLLAND M-1127B, A
Hi-Lo TCH Fluid No. 145 FNHA-2-C-201 (Replaces M-1129A
ESN-M2C134-D) M-1145
ESN-M2C134-D, C
ESN-M2C53-B, A
CASE INTERNATIONAL ESN-M2C41-B, A
JIC-145 (MS-1210) ESN-M2C48-B SPERRY NEW HOLLAND
JIC-185 (MS-1204) ESN-M2C86-C, B
Powerguard™ PTF (MS-1206)
Hy-Tran® Fluid B-6 STEIGER
Hy-Tran® PLUS (MS-1207) Hydraulic/Transmission
Hy-Tran® ULTRA (MS-1209) Fluid
INTERNATIONAL
JOHN DEERE HARVESTER
Hy-Gard® Hy-Tran® Fluid B-6 VERSATILE
J14B
J20A VOLVO WB101
J20C KUBOTA
Quatrol™ UDT Fluid WHITE FARM (UHTF Type 55)
Super UDT Fluid Q1826
Q1705
LANDINI Q1766
Q1802
(1) Meets the performance requirements of Allison C-4 as specified by John Deere.
NOTE: The trademarks listed belong to the indicated companies.
D a t e 1 / 0 9 - ( C o n t i n u e d )
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
David Bradley Manure Spreader (A50515)
David Bradley...
2014 FOREST RIVER WILDWOOD CAMPER TRAILER (A50854)
2014 FOREST RIVER...
