Rear worm lights for Kubota mx5100
   / Rear worm lights for Kubota mx5100 #1
ster009
canada
2013 Kubota MX5100
Im looking to add some rear work lights to the tractor and Im wondering if any of you out there have completed any such mods before. Im havin trouble to find rear power.... any tips.hints or suggestions would be cool. Cheers
   / Rear worm lights for Kubota mx5100 #2
There's are 2 wires directly under the tail light on both sides. One us power other is ground. I put on a Walmart 55w halogen instead of the $100 Kubota one
   / Rear worm lights for Kubota mx5100 #3
If you are going to add lights ,they may as well be LED"s.Much ,much brighter and use less power.
do you know the amperage?are these two wires on the same circuit as the tail lights or seperate? thanks for the help... its dark now around 1930 and i want to keep working!! lol
   / Rear worm lights for Kubota mx5100 #5
If its anything like my BX there should be a pair of wires under one of your tail lights. They may be wrapped in electrical tape. Mine were stubbed into bullet connectors and are on their own separate 15 amp circuit. As noted above go with LED lights- unless you go über crazy with led lights and turn your tractor into a Christmas display or try and signal low flying planes with them you shouldn't have a problem with amperage.
Alternately you could tap into the wiring circuit for your headlights or tai lights. I didn't because I liked have my front and rear aux lights on separate switches
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
43020 (A51691)
43020 (A51691)
