Rear Wheel spread
   / Rear Wheel spread #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Rear Wheel spread
Looks like with NH boomer you can adjust the spread between the rear wheels in 6 different stages or positions. Varies from 47.1 inches to a maximum of 67.4 inches.
Question:
How do you know what the spread should be? 47? 67??? Is their any logic to picking the spread? Wider is better for stability of course, but is there to much spread?
Bob
   / Rear Wheel spread #2
You want to fit ramps on a trailer? you have row crops to straddle? you want a mower to cover your foot print?
Etc..
Soundguy
   / Rear Wheel spread
</font><font color="blue" class="small">( You want to fit ramps on a trailer? you have row crops to straddle? you want a mower to cover your foot print?
Etc..
Soundguy )</font>
Yes (trailer, but dealer trailer only, I am not trailering this thing, no truck and no trailer big enough to safely move it), yes, I want to use it to do a big garden, but how do I choose the wheel spacing? Mowing, it will never do a lawn, just a bush hog. Is foot print important?
Thanks for your thoughts.
Bob
   / Rear Wheel spread #4
</font><font color="blue" class="small">( Yes (trailer, but dealer trailer only, I am not trailering this thing, no truck and no trailer big enough to safely move it), yes, I want to use it to do a big garden, but how do I choose the wheel spacing? Mowing, it will never do a lawn, just a bush hog. Is foot print important? )</font>
Bob, if you plan on row crops, the best alignment of the rear wheels is the same or slightly wider than your front wheels. That way when you place your front wheel in a furrow, you know the rear will follow. I think that's the way the tractor normally comes from the factory. Only if you are working on hillsides or have a specific reason, would you need to change the spacing. My tractor has the same spacing as the day I picked it up. The rear wheel outside-to-outside on my tractor is about 68" I believe (if I remember my last measurement correctly). Also, that way, any 6' mower or implement can cover the rear wheel width and you can get it into any trailer as Soundguy mentioned.
   / Rear Wheel spread
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Yes (trailer, but dealer trailer only, I am not trailering this thing, no truck and no trailer big enough to safely move it), yes, I want to use it to do a big garden, but how do I choose the wheel spacing? Mowing, it will never do a lawn, just a bush hog. Is foot print important? )</font>
Bob, if you plan on row crops, the best alignment of the rear wheels is the same or slightly wider than your front wheels. That way when you place your front wheel in a furrow, you know the rear will follow. I think that's the way the tractor normally comes from the factory. Only if you are working on hillsides or have a specific reason, would you need to change the spacing. My tractor has the same spacing as the day I picked it up. The rear wheel outside-to-outside on my tractor is about 68" I believe (if I remember my last measurement correctly). Also, that way, any 6' mower or implement can cover the rear wheel width and you can get it into any trailer as Soundguy mentioned. )</font>
Good to know. So yours is about 68", which appears to be as wide as they can be set. Thanks for measuring yours. I am going to guess that they set them as wide as they can at the factory. I wonder if the narrow (less than 68") settings are the exception to the rule?
   / Rear Wheel spread #6
You may not need the widest setting, but I think You will find one of the wider settings will be best. Unlike Kubota's which are shipped caged/crated, the NH compacts are shipped with the ordered wheels/tires installed, so a trip to the dealer beforehand to pick out Your settings would be a good idea. The dealer should adjust them at no charge during set-up. The rears tend to be a little heavy and even more difficult if the rims have to be moved on the centers versus just switched side to side.
   / Rear Wheel spread
</font><font color="blue" class="small">( You may not need the widest setting, but I think You will find one of the wider settings will be best. Unlike Kubota's which are shipped caged/crated, the NH compacts are shipped with the ordered wheels/tires installed, so a trip to the dealer beforehand to pick out Your settings would be a good idea. The dealer should adjust them at no charge during set-up. The rears tend to be a little heavy and even more difficult if the rims have to be moved on the centers versus just switched side to side. )</font>
Excellent suggestion. I will do exactly that before I take delivery. I do not want my first hours spent manhandling heavy tires and an even heavier tractor. Sounds like work! /forums/images/graemlins/smile.gif
Bob
   / Rear Wheel spread #8
Bob, you are comparing "apples to oranges" on the wheel widths. At the beginning of this thread, you said inside wheel widths.
</font><font color="blue" class="small">( ...you can adjust the spread between the rear wheels in 6 different stages or positions. Varies from 47.1 inches to a maximum of 67.4 inches. )</font>
The dimensions I gave you are outside wheel widths.
</font><font color="blue" class="small">( The rear wheel outside-to-outside on my tractor is about 68" I believe )</font>
I checked my Operators Manual and it said R4s (which I have) are 68.3" dished outward on the wheel hubs and 84.2" wide with the wheel hub dished inward. Each type of tire varies, and Ag tires are shown as 66.6" and 82.8" respectively. The front wheels are unadjustable on a 4WD tractor. I guess you could flip the rims, but I've never seen that. A 2wd front end is normally adjustable in width.
   / Rear Wheel spread
Sorry for my confusion and thanks for your clarification. So it appears, if I understand what you have told me, that your setup is at the narrow end of the spectrum?
Bob
   / Rear Wheel spread #10
</font><font color="blue" class="small">( Mowing, it will never do a lawn, just a bush hog. Is foot print important?
)</font>
As I and Jinman stated.. it's generally staus quo to get a mower that covers your tire tracks.
Soundguy
2005 Nissan Titan (A50121)
2005 Nissan Titan...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
15 - NEW BRAKE DRUMS (A53843)
15 - NEW BRAKE...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
