Rear Wheel Spacers
   / Rear Wheel Spacers #1
moeh1
Upstate NY
B2150DT / B2150 Hydro / Hinomoto JF-1
It is almost tire chain season /forums/images/graemlins/frown.gif I got a new set of 2 link chains and am thinking about some spacers to keep them off my fender when they loosen up. I have a blueprint for the spacer that I got somewhere, but still have one question for anyone that has put them on. I have 4 bolts on each wheel, which I am certain that I can replace with longer one, but I also have 2 studs - do you press these out and replace with longer ones? Are they a dealer item?
Thanks for any advice
   / Rear Wheel Spacers #2
Marty
The spacers I have on my B2910 use the same bolts and studs to fasten the spacer to the axle. A new set of bolts and studs are required to mount the wheel to the spacer.
Here is a link to a picture of my spacer. Click Here
Ron,
thanks for the picture, I hadn't thought about that as an option. I have another actual blueprint that somebody posted once with only the 5 holes in it, so I had that on the brain. That one used longer bolts right through the spacer so it was made out of aluminum. Given that yours has a bit more stress on it is your spacer steel?
Thanks.
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A53843)
2019 TRITON...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
SHOP FAN (A53843)
SHOP FAN (A53843)
Ammco Brake Machine (A53424)
Ammco Brake...
