Rear Tractor light DK35
   / Rear Tractor light DK35 #1
JeffandTamara
Kentucky
Kioti DK35, Case 1190
The rear light on my DK35 is SHOT. The inside has pretty much deteriorated and the plastic case has some hairline cracks..I think the plastic has just gotten brittel and cracked.
(1) The bulb size appears to be different than a standard automotive light...Any ideas on a replacement bulb part number?
(2) Replacement of the assembly is the prefered solution,,,any suggestions on a replacement product?
(3) I would like to put in two additional lights on the ROPS, I have seen others do something like this...Could it be wired right from the rear spot lite wiring??
   / Rear Tractor light DK35 #2
Hi Jeff,
The bulb # T4340-33682 a few dollars.
The light however is more expensive #T2610-34502 around $40-45.00.
The reason is the dual operation with the back-up switch and the on switch on the light itself.
Most dealers will have this light or bulb in stock.
KiotiDave
I'll ask the obvious quesiton....
Is there a generic bulb replacement for - "The bulb # T4340-33682"
Since the Lighting Case is really in bad shape, I don't think I would spend much money on buying another that might be as prone to failure, and would require propriatary bulbs everytime one burns out.....
   / Rear Tractor light DK35 #4
I had a light go out and just went to an auto parts store and matched the voltage and wattage of the bulb and the dual filament inside also, be sure to look at the outside case of the bulb for the pin arrangement. some are even heghts on both sides some are staggered. the pins lock the bulb in the light fixture.
Update:
It appears the bulb size for the rear work light is a standard 2 filiment typical brake/tail light. The size of the bulb, diameter of the bulb base and orientation of the offset ears appears to be this standard size. I bought the Kioti bulb and tried to install it with no luck. The fixture has corroded to the point where the bulb could not be inserted correctly. I think it is time to look for a different solution.
Thanks for all the help.
   / Rear Tractor light DK35 #6
Why not just replace it with awork light from tractor supply, wal-mart, automotive store. They are cheap.
1995 Polar Tank Tanker Trailer (TITLE) (A50774)
1995 Polar Tank...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-250...
2011 Ford F-350 XL (A50120)
2011 Ford F-350 XL...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
