Rear Blade rear tractor blade
   / rear tractor blade #1
bigtrough
i need advice on what to buy to build and maintain ranch roads in Texas hill country including ditches on either side. i am looking at blades that are either 2 or 3 way mechanical or hydraulic tilt to be pulled behind Kubota 90hp
   / rear tractor blade #3
The land pride that was listed is a good blade. Rhino (models 950 & 1540) and Woods (models RB850 & RB900) also make good rear blades as well. For your application besides adjusting angle and tilt, you will need to have offset adjustment as well. For occasional use, these can be adjusted manually; however, if they will be used frequently, the adjustments can also be performed hydraulically. Obviously, hydraulics add to the blade cost.
2018 Ford Escape (A50324)
2018 Ford Escape...
UNUSED FUTURE MINI SKID STEER TRENCHER (A51244)
UNUSED FUTURE MINI...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52128)
John Deere 5090E...
2017 VOLVO ECR88D EXCAVATOR (A51242)
2017 VOLVO ECR88D...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
