Tires Rear tire question
   / Rear tire question #1
passgas55
Bronze Member
I have a 2210 and notice that part of the bead on my rear tire is riding on the steel rim. Both rear tires on the inside & outside are doing this. I say about a 1/4 of the tire. I am running 20 lbs. Is this normal? Should I get the tires reseated? What can I do to keep this from happening again? Thanks
   / Rear tire question #2
I had a ym2000 before and it done that. I was running about the same air pressure you are. In fact one day I got in a bind with it down the hill and the tires seemed to be flat. I finally got it out and noticed it was doing as your's are doing now. I reseated them and filled them with more air, never had the problem again. That will puncture your tube eventually.
I measured the lug nut on the rear tire with a ruler and it shows around 15/16" but I I know that this may be metric so what size socket would I need to remove the tire from the tractor?
   / Rear tire question #4
15/16 = almost 24 mm That would be my guess as to what it is--24 mm is a common size. A 6 pt socket would definitely work anyway.
Mike
   / Rear tire question #5
The bolt is typically a 16 x 30....16mm, 30mm long. Head size can vary depending on the supplier, but 24mm is typical. Well worth spending $50 for THIS if you have a Yanmar. We have Snap-on, Craftsman, GearWrench, and SK for most of our tools, but a set of those 3/4" drive metric sockets from Harbor Freight has been with us for years. Their primary use is probably wheel bolts.
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
