Rear tire pressures
   / Rear tire pressures #1
Sutol
Cheshire England UK
Ford 1200 / Super Dexta x 2
Any one know off hand what pressure I should put in the rears of my Ford 1200 compact tractor?
they should be 800 x 16 but we have fitted 750 x 16 tires as they look better and are a higher profile.(and cheaper lol)
Brother Edd put 16psi in them but I think that may be a little high.:)
   / Rear tire pressures #2
most rear tractor tires I run 12 in.. but.. look at the tire profile.. you can see when it is correct. IMHO.. if 16 looks ok.. I wouldn't be afraid of it. might be a harder ride.. all up to you..
Feels a bit lumpy on the concrete, cant find any data on pressures so I guess we'll let some out and see.:)
   / Rear tire pressures #4
I usually start with what is on the side of the tire and adjust from there but not much difference.
Maybe when we build up the backhoe and get the rams and dipper back on it will be ok.:)
   / Rear tire pressures #6
Most rear tires are in the range of 10-12 psi, but put your heaviest load on the tractor, then drive it onto a flat conrete or paved surface. Deflate or inflate until full width of tread (ie; shoulder to shoulder) is touching the surface. This will give you the maximum contact patch for maximum traction and the most comfortable ride. This is same for R1,R2,R3,R4's.
Front tires are different because most are under much more load and require more pressure to keep bead from rolling off rim when turning and carrying a full load on the loader. Quite often 30-40 psi.
Always consult your owners manual for proper inflation pressure for your tractor/tire combination.
   / Rear tire pressures #7
Massey calls for 12 psi in ballasted rears and 29 in the front.
2014 Freightliner M2 106 Medium Duty Truck with Tool Bed, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
LOT NUMBER 251 (A53084)
LOT NUMBER 251...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2023 JOHN DEERE 8R370 LOT NUMBER 201 (A53084)
2023 JOHN DEERE...
